arp head bolts for ls vtec
Old Oct 13, 2003 | 09:59 PM
riceball777's Avatar
Default arp head bolts for ls vtec
i'm in the process of building my ls vtec and are the arp head bolts a real must have when building a ls vtec. i know that the rod bolts are a must have and i already got them but are the head bolts a must have?
Old Oct 13, 2003 | 10:05 PM
Combustion Contraption's Avatar
yes. ls/vtec is like forcing a round peg into a sqaure hole as far as bolting the head onto the block. ARP head studs will go a LOOONG way into making sure the head stays on nice n tight.
Old Oct 14, 2003 | 12:46 AM
aira
Guest
Posts: n/a
Default Re: (LsVtec92Hatch)
it's just extra insurance...
i would definately get it though if i were u
Old Dec 9, 2003 | 12:37 PM
jdmDB1's Avatar
which ARP head studs you use when using a B18a block and a B16a head?
Modified by jdmDB1 at 2:13 AM 12/10/2003
Old Dec 9, 2003 | 01:04 PM
lsvtec hatch05's Avatar
Default Re: (jdmDB1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmDB1 &raquo;</TD></TR><TR><TD CLASS="quote">which ARP head studs you use buy when using a B18a block and a B16a head?</TD></TR></TABLE>
this i would like to know too
Old Dec 9, 2003 | 02:16 PM
sander's Avatar
2.7(p/t)
Default Re: (lsvtec hatch05)
GSR head studs.
I wouldnt go past 70 lbs/ft i had gasket seating problems past that amount of torque.
-sander
Old Dec 9, 2003 | 05:08 PM
trackmasters's Avatar
Default Re: (sander)
You can use the GSR or ARP makes the LS/VTEC head studs suppose to be specifically for LS/VTEC but could just be reboxed GSR studs. Never measured them. Try the sponsored marketplace. AEBS also makes nice studs too
brian3676
Dec 14, 2005 05:45 PM
SPOOLINmatt
Apr 8, 2005 12:40 PM
frostt3ch
Dec 31, 2003 08:18 PM
logistixz
Oct 8, 2002 06:20 PM
paulzy
Nov 9, 2001 03:41 AM
