c-speedracing compression calculator accurate?
Old Oct 13, 2003 | 08:24 PM
shant's Avatar
Default c-speedracing compression calculator accurate?
http://www.c-speedracing.com/h...c.php
ive been using this site to see possible compression differences, but i was wondering if its accurate
for example my motor is stock 81mm bore LS bottom end with type R/B16 head. pr3 pistons and stock head gasket
it said that the cr was 11.3 correct?
Old Oct 13, 2003 | 09:21 PM
96dxB16's Avatar
Default Re: c-speedracing compression calculator accurate? (shant)
i know it is inaccurate to the point of B16 blocks, it says the B16A/B are the same, which is totally not true.
Old Oct 13, 2003 | 09:25 PM
riceball777's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shant &raquo;</TD></TR><TR><TD CLASS="quote">http://www.c-speedracing.com/h...c.php
it said that the cr was 11.3 correct?</TD></TR></TABLE>
correct
i think its preatty much accurate
Old Oct 14, 2003 | 04:50 AM
advanracing62's Avatar
Default Re: c-speedracing compression calculator accurate? (riceball777)
it is off on PCT pistons by about .2
Old Oct 14, 2003 | 09:30 PM
THE GAME IS THICK's Avatar
Default Re: c-speedracing compression calculator accurate? (advanracing62)
i was just messing around and i calculated a b18b block/head and oem head-gasket with ctr pistons and it put out 11.4. Is this possible? would it be even benificial for me? this would be greatly appreciated.
Old Oct 14, 2003 | 09:34 PM
shant's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by advanracing62 &raquo;</TD></TR><TR><TD CLASS="quote">it is off on PCT pistons by about .2</TD></TR></TABLE>
+/- .2 on the PCT pistons?
hamilton9339
Aug 15, 2011 09:44 PM
Ransom
10
Jul 31, 2007 01:50 PM
94sol
Nov 10, 2005 09:33 PM
bOOsTiNSoHcVtEc
Jul 6, 2005 06:34 PM
crxjake
Jun 29, 2004 12:12 PM
