boost on b16 map sensor promlem help
Old Oct 13, 2003 | 08:10 PM
16STCRX's Avatar
Default boost on b16 map sensor promlem help
i need help i'm gonig to have my car tuned this week for the track and i need to find out what i need to do to fix the map sensor proble thanks
Old Oct 13, 2003 | 08:16 PM
16STCRX's Avatar
Default Re: boost on b16 map sensor promlem help (16STCRX)
every time i get to about 6000 rpm the map sensor sends ecu error i'm only running 5psi is there a way to trick the map sensor or is there a problem with the set up
Old Oct 13, 2003 | 08:20 PM
90civichbsi's Avatar
a map bypass valve will do the trick http://www.importparts.com has em for 70 bucks
Old Oct 13, 2003 | 08:26 PM
16STCRX's Avatar
Default Re: boost on b16 map sensor promlem help (90civichbsi)
does that work with obd0
Old Oct 15, 2003 | 08:57 PM
laosb904's Avatar
just use check valves if your map sensor is on the firewall and not on the TB.
Modified by laosb904 at 6:18 AM 10/16/2003
reddysol
Sep 8, 2007 10:57 AM
NSfit
Oct 29, 2006 12:34 PM
zman
Jun 15, 2006 07:40 PM
LSVtechnologytur...
Dec 9, 2004 04:26 AM
