what type of flywheel to use on a turbo car with 500+ wheel hp?
i have a toda flywheel would i need to change that or would it be ok if i just used that? i am really not familiar so any help is greatly appricated.
toda flywheel's are actually made very well. How many lbs is your flywheel?
Bang for the buck and weight wise would go to the type r flywheel.
well i already have a Toda flywheel i think its 7.9lbs. would it be wise for me to change it to the ITR flywheel?
a lighter flywheel would mean that your rpm would rise faster as compared to a heavier flywheel but as with anything that you do there is a con with a lighter flywheel. Rpm will also drop faster due to the lighter flywheel so just learn how to shift really fast..
if you shift fast then the lighter flywheel can be an advantage for you.
well ive been driving arould with this flywheel for the past 7k miles. so im used to it. i just wanted to make sure that i could use it and it wouldnt be a major problem.
See Are X
Jun 17, 2008 08:33 PM
b16vtecsol
May 10, 2004 12:10 AM
