swap issue
Old Oct 13, 2003 | 06:56 PM
Origin's Avatar
Default swap issue
got to the point of taking out the fuel filter line. i saw a picture of all of its components but im not exactly sure what each part is so that i can dissasemble it correctly to take out my engine in my 88 crx hf. can anyone help me out.
Old Oct 13, 2003 | 07:00 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: swap issue (Origin)
what are we swappin'?
just unscrew the big clear thing on the fuel rail..
top center of pic:
Old Oct 14, 2003 | 09:41 AM
revhigh89's Avatar
Default Re: swap issue (88DXCRX)
well the thing on the top right screws on the fuel filter, which is the black round cylinder like thing, there are 2 bolts on top of the filter and a little hole in each screw, tahts how the filter goes through the 2 ring things with hose attached to them hook up, the 2 ring things with hose attached has a little hole in the underlying of the ring so u have to align the 2 little holes to the ones on the screw on the fuel filter. There should be 2 washers for each othe screws when u take it off or put it on whatever, one on top and one on the bottom totalling 4 washers, there's a view of one washer right between the ring thing and the nut looking thing on top, that nut thing, (should have 2 of them) bolt down and fassens everything down , make sure u align those holes so the fuel can flow, or else ur car is gonna choke for gas...and make sure u tighten it down good or u gonna be leaking gas, i forgot which socket u have to use, its a pretty good size one,.....
ek747
Sep 20, 2010 01:30 PM
supamike3232
Oct 18, 2007 08:24 AM
ForceXVII
Jun 25, 2006 09:39 AM
4inspeed
Dec 29, 2003 11:31 PM
AK94GSR
Aug 7, 2002 08:02 PM
