wheelie bars
Old Oct 13, 2003 | 05:59 PM
xrtdac
Guest
Posts: n/a
Default wheelie bars
Anyone know where to get them that may be pre-fabbed for integras?
Old Oct 13, 2003 | 06:09 PM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: wheelie bars (xrtdac)
Art morrison sells them, i forget the website. and i think http://www.KensKustomChassis.com
Old Oct 14, 2003 | 08:28 AM
xrtdac
Guest
Posts: n/a
Last I heard those are ungodly expensive
Old Oct 14, 2003 | 08:37 AM
DaveF's Avatar
Default Re: (xrtdac)
i paid around 1300 for mine.
Old Oct 14, 2003 | 08:44 AM
HT's Biggest Loser
Drag racing isnt cheap man
Old Oct 14, 2003 | 09:44 AM
xrtdac
Guest
Posts: n/a
I am probably gonna have Brent Rau from Osofast do mine for me.
Old Oct 14, 2003 | 10:08 AM
bambooluv's Avatar
If you or a competant welder around are up to the challenge than give http://www.Jerrybickel.com a try for thier universal kit. Other than that the http://www.Kenskustomchassis.com kit is actually pretty complete and cheap for everything it comes with. The wheelie bars complete with rod ends, wheeliez orange wheels (one of the best wheel companies,) extra tubing to fab the mount to the chassis. Ill try to get a pic up as soon as my ar is alittle more complete. hehe when ever that happens.-pdang
Old Oct 14, 2003 | 11:35 AM
cmiracer's Avatar
Default Re: (2.2Lcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic &raquo;</TD></TR><TR><TD CLASS="quote">i paid around 1300 for mine.</TD></TR></TABLE>
Damn ,, that is hella money for Wheelie bars .
Material probably cost him at the most $200 bucks
and 2 hours of labor .. That comes to $550 an hour .... HA HA
So that's were the money is at .
Anyway I like your Chassis work . Who did that for you ?
I looking also ...
Old Oct 14, 2003 | 11:59 AM
DaveF's Avatar
Default Re: (cmiracer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cmiracer &raquo;</TD></TR><TR><TD CLASS="quote">
I looking also ...</TD></TR></TABLE>
2hours of labor.....id love to see you do this...the guy has way over 2 hours of labor into the bars..they are chromoly, tig welded and adjustabel..the top tube spins to raise or lower the bars. and the bars that attach the upper to lower tubes are adjustable as well to get any slack out of the bars. you cant forget how much rodends, quick pins, brakets, wheels, etc cost. cut tubes to get a perfect fit, plus to get them all setup completly straight and welded, and keep them straight after they are welded....it takes time
Old Oct 14, 2003 | 12:07 PM
cmiracer's Avatar
OK 3 hours
Old Oct 14, 2003 | 12:08 PM
Clayton's Avatar
H-T Administrator
25 Year Member
Good reply. There is NO WAY someone could make a decent set of wheelie bars in 2 hours. There is more than that in just measurig and cutting the tubing.
Clayton
Old Oct 14, 2003 | 12:11 PM
xrtdac
Guest
Posts: n/a
See I am going to go with a simpilar lighter set-up. Only needs 3 main bars, with a cross brace between them and a single wheel. similar to the Pro funny cars.
Old Oct 14, 2003 | 12:12 PM
DaveF's Avatar
http://www.ericksracing.com &lt;--has the trianguler wheelie bars
Old Oct 14, 2003 | 12:18 PM
cmiracer's Avatar
That one is made at RLR . And it starts at like $800 ...
Old Oct 14, 2003 | 12:20 PM
integra_gsr98's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xrtdac &raquo;</TD></TR><TR><TD CLASS="quote">See I am going to go with a simpilar lighter set-up. Only needs 3 main bars, with a cross brace between them and a single wheel. similar to the Pro funny cars. </TD></TR></TABLE>
I don't think you would even need wheelie bars. Cars go 10s all day without them.
What suspension setup are you running? Do you have any form of traction bars up front?
Old Oct 14, 2003 | 12:26 PM
bambooluv's Avatar
Trust me thats a deal on Daves setup. Go ahead and ask tony1 how much he would charge to make a set like that especially in 2 hours? the kits you see on art and jegs are designed for domestics. They USED to work when the sport first started using them, but now 65" being the norm the only company that has steped up to the bat is kenskustomchassis.com so until someone else comes out with something its either kens kit or custom like daves, which is a great setup.-pdang
Old Oct 14, 2003 | 12:31 PM
cmiracer's Avatar
Default Re: (bambooluv)
Like I said , it's not that hard to measure a few straight bars and tig it together .
There is no brain to that. The setup is so simple yet so much . You act like we're charging for frame work here .
Modified by cmiracer at 9:54 PM 10/14/2003
Old Oct 14, 2003 | 01:33 PM
obsessionx916's Avatar
yup mb products sell a custom premade wheelie bars give them a call 661 321 0148
Old Oct 14, 2003 | 01:48 PM
SEFIxCivic's Avatar
you'd be surprised how hard it is. if it's so simple, then fab one yourself, and see how it turns out in comparison to the one shown.
Old Oct 14, 2003 | 01:51 PM
xrtdac
Guest
Posts: n/a
Only reason why I was going to do one was because my suspension is still squishy yet and I wanted to try and help keep the fronts from spinning. I will see after this weekend because we are going to a better track.
Old Oct 14, 2003 | 03:15 PM
Tyler another thing to try...
Coil the *** of the car all the way up and stiffen up your struts if you can.
What do you run for air pressure? 2nd gear burnouts? How do you launch?
Old Oct 14, 2003 | 03:43 PM
dmotoguy's Avatar
Default Re: (integra_gsr98)
i don't think raising the rear of your car will help, especially with soft suspension. you want to minimize rearward weight transfer
Old Oct 14, 2003 | 04:02 PM
cmiracer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xrtdac &raquo;</TD></TR><TR><TD CLASS="quote">Only reason why I was going to do one was because my suspension is still squishy yet and I wanted to try and help keep the fronts from spinning. I will see after this weekend because we are going to a better track.</TD></TR></TABLE>
On the drag racing forum , there is a topic name .
what to do with the rear end , you need to go read that , cause you don't know what your talking about !!!!
RAISE THE REAR END !!!!!!!!!!
People we're not talking about chassis work here , WHEELIE BAR and COST was the subject stick to it or move on . I know it does not cause that much to make one and people are charging two arms and three lags here .
Keep looking , that's all I can tell you .
Old Oct 14, 2003 | 07:48 PM
xrtdac
Guest
Posts: n/a
I think from that I am understanding raising the rear suspension helps increase tension in the rear springs thus making them harder to compress due to the launching.
Old Oct 14, 2003 | 08:04 PM
dmotoguy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xrtdac &raquo;</TD></TR><TR><TD CLASS="quote">I think from that I am understanding raising the rear suspension helps increase tension in the rear springs thus making them harder to compress due to the launching.</TD></TR></TABLE>
as far as i know with all of the coilovers i have ever used that is not true.. they dont get stiffer when you raise it up
