2.0 time slip?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedyonez »</TD></TR><TR><TD CLASS="quote"> i wonder what more i neeeed..</TD></TR></TABLE>
Uhhh traction maybe?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr Milano »</TD></TR><TR><TD CLASS="quote">
yeah def need traction what kind of tires did you use and how much wear? 60ft of 2.4 is pretty high with that wild of a setup you should be able to hit 13's on good street tires no problem
</TD></TR></TABLE>yeah def need traction what kind of tires did you use and how much wear? 60ft of 2.4 is pretty high with that wild of a setup you should be able to hit 13's on good street tires no problem
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Drag R »</TD></TR><TR><TD CLASS="quote">are you babying the car???</TD></TR></TABLE>
Thats what I"m thinking considering you have all that work done to it, that thing should be stupid fast, your traps are kind of low, but I understand its your first time out, so go take another stab at it.
Your 60ft is your weak point, did you roast your tires or bog out of the hole at 3000rpm? When I first started dragging my Integra, 2.4 60ft was the best I could get, maybe 2.3sec with a lucky spin and grab. I then switched to BF Goodrich G-Force T/A drag radials,205/50r15. That got me 2.2 60ft. With about 20 passes worth of practice, I managed to get 2.0-2.05sec 60ft consistently. That's launching at 6500rpm and slipping(not dumping) the clutch as fast as I can without the engine bogging. The drag radials are street legal, and I've driven on them all summer.
welll tread was 50%.... heh bogging ? are you serious? they went up like nothing i think i pop'd the clutch at 3-3500 at the most... but uhmmm i figure that the trap was real slow to.. but my lower control arm bushings where completly shot i just put new ones on and my shocks where shot. i just got new ones to... and that was with like 210whp.. becuase i didnt unbolt the exhuast with it unbolted it did 220whp er 222whp ... <---untuned... i just got hondata data-loggin and rom editor fixin to get it tuned,, with 2.0 60ft.. what do you think i would have done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by goforbroke »</TD></TR><TR><TD CLASS="quote"> stupid fast</TD></TR></TABLE>
lol... stupid fest
lol... stupid fest
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedyonez »</TD></TR><TR><TD CLASS="quote">hmmm anyone else?
Get some traction bars like the Jimfabs ones or DTRs and just practice your takeoff, don't be afriad to eat up the clutch, just practice, practice and more practice.
Shet takes time
Shet takes time
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by speedyonez »</TD></TR><TR><TD CLASS="quote">t-y bert-o ... i will check into that... i am going to get some drag radials and see if it does anything...</TD></TR></TABLE>
You need slicks!
nick
You need slicks!
nick
if u make like 2 more passes, u will have consistant mid-high 13's...u should easily be able to get 2.2 outta those tires. My first time to the track on stock bald tires I didn't pull anything worse than a 2.3
good luck bud!
mike
good luck bud!
mike
you should be hitting 13s with an engine like that. Don't laucnh at 3000-3500 launch at 5k or over. I think you just have to work on your driving, like everybody says 2.4 60ft. times say either you have absolutly no traction at all, or need to work on your launch.
*edit - sell me your engine
Uhhh Ya I agree with the traction issue that will be a very hard task to hit a low 13 on street tires let alone 13.0. Your best bet will be to buy a set of the mickey tompson street drags radials they are basically a slick but they have one rib down the side of them that makes them street legal.
</TD></TR></TABLE>Uhhh Ya I agree with the traction issue that will be a very hard task to hit a low 13 on street tires let alone 13.0. Your best bet will be to buy a set of the mickey tompson street drags radials they are basically a slick but they have one rib down the side of them that makes them street legal.
Hmmm,
the 60 foot time is not a surprise with the tyre and power output.
HOwever as previously stated the trap speed should be much higher.
I run a standard GSR motor with I/H/E and ran a 14.3 at 100mph. (DOT tyres)
Faster shifting is the only thing I can think of unless your motor is not performing.
There is the old tale of practice makes perfect.
Give it a few more runs before you give up on 13's.
Bulldogg83
Mar 7, 2004 11:44 PM
