Question on 4th Gen JDM head lights??
You should really do a search as there have been LOTS of threads about the JDM headlights already. But I'll help you out anyways...you have to rewire your stock headlight harnesses with some H1/H4 harnesses. Most seller usually include the harnesses with the lights but if yours don't come with them, you can pick some up at a junkyard, usually from a Civic.
the archives has alot of information, this is a very popular topic. but to some it up you need an h4 harness to at least get the low beams..
its really pretty simple and everything besides the actual headlights is fairly inexpensive
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TURbb1 »</TD></TR><TR><TD CLASS="quote">my headlights came with the harnesses. all i had to do was splice the stock wires to the ones coming from the jdm harnesses</TD></TR></TABLE>
So did mine. If you order from http://www.passwordjdm.com , you will get harnesses and bulbs along with the housing. Then all you have to do is splice the wires and you're set...
Simon_the_Pieman
Jan 29, 2003 05:51 AM
