Valve Adjustment HELP!!
Old Oct 13, 2003 | 04:39 PM
MrEg's Avatar
Default Valve Adjustment HELP!!
lets say i just adjusted my valves.....if i adjusted them wrong ....
what can go wrong and/or what noises can they make..
car is making a vibrating noise around 3k rpm...
could it be that im sooo retarded that i need to re-adjust the suckers...
HELP
Old Oct 13, 2003 | 04:47 PM
sleepyEK's Avatar
Default Re: Valve Adjustment HELP!! (mr_timluu)
why is my girlfriend on your avatar? you need to elaborate a little on the "vibrating noise." i have seen people adjust them to loose and it creates a little more tapping noise from the valve train. if you used feelers and the correct specs, then i doubt you adjusted them to tight.
iloyola
Jul 27, 2005 01:53 PM
MrEg
Oct 13, 2003 04:51 PM
redlinex
Sep 19, 2003 07:52 AM
Nizzy
May 17, 2003 03:14 PM
BryanS
Sep 25, 2001 10:46 AM
