JDM ITR Spoon Pistons with Fully P/P Gs-R head
Old Aug 30, 2001 | 10:59 PM
905_S2K's Avatar
New User
Default JDM ITR Spoon Pistons with Fully P/P Gs-R head
I've read in a few other threads that having JDM itr pistons or the JDM balance Spoon pistons yield an approx. compression ratio of 11.4:1 in a Gs-R motor due to the fact that the Gs-R has smaller combustion chambers. A few of u have confimed this, but what if the Gs-R head was full ported and polished? What would the compression ratio be then? I hoping to get these pistons sometime shortly and was curious as to what compression ratio i might be running since my head is fully p/p and is also milled 40thou. Figuring out how much added compression i get from my milled head is not too difficult, but getting an idea of what compression i will be running from the JDM itr OEM or Spoon pistons with my p/p head has me wondering.
Old Aug 31, 2001 | 05:57 AM
bigTom's Avatar
Default Re: JDM ITR Spoon Pistons with Fully P/P Gs-R head (Mugen-EG6)
porting and polishing the head will not effect the c/r... porting and polishing means the runners going into the combustion chamber are opened up... it has nothing to do with the actual combustion chamber... also take into account what valves u are using... as any "flat head" valve will also yield u a higher compression, as will milling the head
hYbRid_Eg6
Dec 20, 2009 07:01 PM
jeremy.
Jul 13, 2003 08:31 AM
DYI01
Mar 20, 2002 01:47 PM
OBD-One-Kanobe
Sep 17, 2001 02:54 PM
