DA Mounts. 90-91 ~ 92-93. Difference???
Old Oct 13, 2003 | 03:43 PM
Andres-eh2's Avatar
Default DA Mounts. 90-91 ~ 92-93. Difference???
My friend totalled his 93 LS. Went and got a '90 shell for $200 and swapped the '93 motor with all the components into the '90 shell. Last week he broke the driver side mount (by the cam gears) and an axle. Now he bought a '90 LS replacement mount and the motor sits crooked. We believe that this is why he broke the other mount in the first place.
Is he using the correct mounts???
TIA
Old Oct 13, 2003 | 03:50 PM
DoctorGSR's Avatar
they are all the same. spend the $50 and get the prothane motor mount bushings.
Old Oct 13, 2003 | 03:52 PM
Andres-eh2's Avatar
what would cause his motor to be crooked? should he loosen the other mounts to put the driver side mount on?
Old Oct 13, 2003 | 05:24 PM
Andres-eh2's Avatar
bump
Old Oct 15, 2003 | 03:41 PM
emissionsux's Avatar
Default Re: DA Mounts. 90-91 ~ 92-93. Difference??? (EGEESIX)
Nope....90-91 and 92-93 are different. The driver's side is different.
Old Oct 15, 2003 | 06:58 PM
Andres-eh2's Avatar
so what should my friend do to correctly mount his motor.
Currently using 93 mounts all around and broke the driver side one. Ordered a 90 driver side mount but still sits crooked.
Old Oct 15, 2003 | 07:40 PM
Default Re: (EGEESIX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGEESIX &raquo;</TD></TR><TR><TD CLASS="quote">so what should my friend do to correctly mount his motor.
Currently using 93 mounts all around and broke the driver side one. Ordered a 90 driver side mount but still sits crooked.</TD></TR></TABLE>
If you are using a 90 shell, you need to use a 90-91 driver's side motor mount bracket. The 2 are completely different.
t0kyoStatus
Mar 6, 2009 11:09 PM
strictlyimport
Jun 19, 2005 06:18 AM
rocketfuelcerx
Apr 8, 2005 11:53 AM
Andres-eh2
Oct 15, 2003 09:36 PM
crex23
Oct 11, 2003 06:02 PM
