Help me!! rear suspension LCA bushing??
Old Oct 13, 2003 | 01:48 PM
HATCHingMN's Avatar
Default Help me!! rear suspension LCA bushing??
Okay!! so heres my problem...I trying to replace my EG's rear stock strut/spring and it seem the screw that hold the rear strut inplace are rusted w/ the sleeve.. even worst I try to unbolt the LCA, where the strut is sitting and broke the screw in half ....plus!!.. on the other side I broke the cap off the screw!! Now I'm toast!!!...so here I took it to the narest brake/shock/strut shop, the guy in there told me that I need a whole new LCA,..I thought I only need a new bushing!! am I right?...can I just cut and drill the rusted screws/sleeves out and replace with two new bushing for both side???Please help asap!! Thanks in advance!!
Old Oct 13, 2003 | 01:56 PM
Mista Bone's Avatar
D Tranny Guru
Default Re: Help me!! rear suspension LCA bushing?? (HATCHingMN)
cut through the bolt on both sides of the LCA.
Press out the bushing, cut out the sleeve, push in ES poly inserts.
They are about $20 shipped from http://www.suspension.com
Old Oct 13, 2003 | 02:00 PM
HATCHingMN's Avatar
Default Re: Help me!! rear suspension LCA bushing?? (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">cut through the bolt on both sides of the LCA.
They are about $20 shipped from http://www.suspension.com</TD></TR></TABLE>
Do I reuse the old sleeves or does the ES one came with new slleve??
Old Oct 13, 2003 | 02:25 PM
owen_the_soyboy's Avatar
E.S. poly bushings for LCA's do NOT use the oem metal sleeve.
so cut them out yo!
good luck bro.
Old Oct 13, 2003 | 03:42 PM
HATCHingMN's Avatar
Default Re: Help me!! rear suspension LCA bushing?? (owen_the_soyboy)
Sorry!! I've never order them before, can you please tell me which or parts (parts #) do I need to order?
Old Oct 13, 2003 | 04:50 PM
HATCHingMN's Avatar
Is this the parts that I need for my EG:... "REAR SHOCK UPPER and LOWER BUSHING SET" part#16-8103? Is it for both side at the rear? or just for one side? because I need it for both side at the rear!!
Old Oct 13, 2003 | 05:48 PM
Mista Bone's Avatar
D Tranny Guru
call and ask the order lady. She will know EXACTLY what you need.
Lower shock bushing.
Old Oct 13, 2003 | 08:17 PM
HATCHingMN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">call and ask the order lady. She will know EXACTLY what you need.
Lower shock bushing.</TD></TR></TABLE>
Cool thanks!! I shoulda thought of that first.
Old Oct 13, 2003 | 08:20 PM
yakitori's Avatar
probably just a new bushing but you have to get the control arm off first good luck
Old Oct 13, 2003 | 08:23 PM
-[95cxhatch]-'s Avatar
i had the same prob i just busted out the torch and got them really hot and hammered all the **** out of the lca then went to honda and bought new bushings and bolts.
Old Oct 13, 2003 | 09:12 PM
civic_tuned's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HATCHingMN &raquo;</TD></TR><TR><TD CLASS="quote">Is this the parts that I need for my EG:... "REAR SHOCK UPPER and LOWER BUSHING SET" part#16-8103? Is it for both side at the rear? or just for one side? because I need it for both side at the rear!!</TD></TR></TABLE>
same situation happened to me not to worry its common for hondas. I just got my Energy Suspension #16-8103 this past week and it comes with the upper shock bushing too... cool for 15.00 well 21.00 bucks shipped. i havent had the chance to work on my car. U might want to call the honda dealer for the bolt size cause thats what i did but right now i cant remember the exact size. Also dont forget the nuts.
Old Oct 13, 2003 | 09:17 PM
HATCHingMN's Avatar
Default Re: Help me!! rear suspension LCA bushing?? (civic_type_r)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_type_r &raquo;</TD></TR><TR><TD CLASS="quote">
same situation happened to me not to worry its common for hondas. I just got my Energy Suspension #16-8103 this past week and it comes with the upper shock bushing too... cool for 15.00 well 21.00 bucks shipped. i havent had the chance to work on my car. U might want to call the honda dealer for the bolt size cause thats what i did but right now i cant remember the exact size. Also dont forget the nuts. </TD></TR></TABLE>
Hey is that kit for both the left and right side of the rear LCA? or just for one side?
Old Oct 13, 2003 | 09:21 PM
hatching yes! u get both....just go to http://www.suspension.com. Just to let u know i called the dealer and they want to sell me one side lca bushing for 19.00 and i said hell no!
Old Oct 13, 2003 | 09:35 PM
HATCHingMN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic_type_r &raquo;</TD></TR><TR><TD CLASS="quote">hatching yes! u get both....just go to http://www.suspension.com. Just to let u know i called the dealer and they want to sell me one side lca bushing for 19.00 and i said hell no! </TD></TR></TABLE>
Yeahh..I figure dealer would just rape me for those bushing if I show up over there. But what about them two screws,..do I have to get them from dealer?
Now...I know that the screw that hold the rear suspension inplace are frozen but do the other screw on the control arm got froze too? dont I need to take the whole control arm out?...or..can I replace the bushing while the LCA still on car?
Old Oct 14, 2003 | 06:49 AM
tuphatt's Avatar
right when i thinking where is the post about broken LCA bolts!
I have the same problem.
From my experience I broke the LCA bolt that hold the strut. But I used an electric impact to remove LCA from the frame and the rear disc brake. It wasn't too bad. I know when I am going to break the bolt when i feel the head bolt spin but the back side is not.
I also had bad luck with the front suspension and broke the fork screw that holds the strut into the fork.
not to mention the two stripped rotor screws.
the horror never ends.
I think that is what i get for buying a 92 eg from canada in Houston with no A/C and a lost title.....
But hey what do expect when you paid $600
Old Oct 14, 2003 | 02:21 PM
92B20GSR's Avatar
Default Re: Help me!! rear suspension LCA bushing?? (tuphatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tuphatt &raquo;</TD></TR><TR><TD CLASS="quote">right when i thinking where is the post about broken LCA bolts!
I know what you mean i got the same problem. 92 hatch from canada in missouri. AC didnt work had a title but almost every bushing was completely shot and every nut and bolt is totally rusted. i wish i had a pic on this computer of what my engine bay looked like before i sand blasted it.
93formula
Sep 7, 2005 07:49 PM
Hyb
Feb 16, 2005 07:25 PM
95greenteg
Sep 12, 2004 06:14 PM
001020
Feb 16, 2004 07:44 PM
SL!M
Jun 13, 2003 10:28 AM
