removing ABS - need help/advice
Old Oct 13, 2003 | 10:22 AM
Greyout's Avatar
Default removing ABS - need help/advice
Looking to remove the ABS from a 1992 SI model.
would I buy the brake lines from a 1992 S, or would it be easier to make my own lines?
Old Oct 13, 2003 | 11:47 AM
aklucsarits's Avatar
New User
Default Re: removing ABS - need help/advice (Greyout)
Do you really mean "remove"? Or do you mean "disable"?
If you want to disable ABS, just pull the ABS fuse.
If you want to remove ABS, I can't help you. (And I have no idea why you would want to remove the ABS system...)
Andrew
Old Oct 13, 2003 | 12:11 PM
Greyout's Avatar
Default Re: removing ABS - need help/advice (aklucsarits)
remove, as in remove all hardware, never to be used again.
This is not a street car
Old Oct 13, 2003 | 12:17 PM
JBG's Ferio's Avatar
Talk to Corey, he removed the ABS from his Prelude racecar.
That's about all the help that I can provide
EfSedanLove
Sep 23, 2008 03:12 PM
JDMeman
Dec 26, 2007 12:21 PM
RMOracer34
Nov 18, 2006 10:21 AM
shane
Aug 30, 2003 09:31 AM
