GSR Rear sway bar on EK?
Old Oct 13, 2003 | 10:21 AM
jlamaster's Avatar
Default GSR Rear sway bar on EK?
Will a GSR rear sway bar fit on a EK?
Old Oct 13, 2003 | 10:28 AM
jolt-tsp's Avatar
Default Re: GSR Rear sway bar on EK? (jlamaster)
ya, you need the endlink mounts and the mid-mounts (not sure what they're called, but they normally come with the swaybar, as they don't fit larger diameter ones which is what GSR owners normally go to). You will also need a mount kit, or a few washers will probably also do the trick. I'm doing mine as soon as the endlinks come in, I'll let you know how it goes.
Old Oct 13, 2003 | 11:11 AM
ek9dc2's Avatar
why go with a gsr when you could go with a itr.
The itr is double the size than the gsr,all you need is swaybar, links,bushings,and a beaks
kit, http://www.beaksproducts.com. and its bolt on from there. The difference is amazing
Old Oct 13, 2003 | 12:10 PM
jolt-tsp's Avatar
Default Re: (ek9dc2)
Because I got a GSR for free
Old Oct 13, 2003 | 12:15 PM
EddieHatchBlack's Avatar
Default Re: (jolt-tsp)
Don't forget, you need 99-00 SI Endlinks. You should get that Beaks Reinforcement kit just in case...
EeeJayEight
Apr 7, 2005 07:23 PM
panda'eg
May 27, 2004 09:01 AM
jimmhatch
15
Feb 15, 2004 02:21 PM
ransack
10
Jun 18, 2003 12:50 PM
MeanGreenEG9
Sep 26, 2002 11:07 PM
