oil cooler?
Ok I had an Idea. If you were to have an AT radiator (has connections for radiator fluid cooling) couldnt you concieveably run your oil lines to it and double as a radiator/oil cooler? Istead of cooling AT fluid you would cool your oil. Anyone have anything to support that it wouldnt work?
yeah but the point would be to not have to add an oil cooler you could just get the radiator and use it for both oil and coolant.
Ive swapped in an AT radiator from an integra so its the full width of the car up front. But even with a halfsized radiator the surface size is almost 3 times the size of an aftermarked oil cooler.
Ok so I called performance radiator where I got my integra radiator and they said it absolutely will work. Ill be trying it out here in another week or so. Ill take temps before running it through the radiator and some after and post em.
