? on skunk2 I.M for ls turbo
Old Oct 13, 2003 | 06:49 AM
b18bEG's Avatar
Default ? on skunk2 I.M for ls turbo
OK so I have been pondering on getting one for my ls turbo. As of right now, I will be haveing SRP pistion, eagle rods, anda Block guard for bottom end. I will also have a built head. P&P, 3 angle valve job, and crower everythign else. Im wondering if a Skunk2 I.M. will do me any use. ok by the wany its a drag 3 kit. any input would be helpful. or anything else That I might need to get would be cool. thanks in advance
chris
Old Oct 13, 2003 | 07:41 AM
R6Elmo's Avatar
Default Re: ? on skunk2 I.M for ls turbo (b18bEG)
People have stated that the skunk2 manifold makes good power depending on how much power you inted to have run. If you are boosting under 10psi, it might not be needed. But on a built motor running higher boost, it will help a lot. The LS manifold is pretty darn restrictive.
Old Oct 13, 2003 | 08:18 AM
T4eg's Avatar
Default Re: ? on skunk2 I.M for ls turbo (R6Elmo)
skunk2 I.M. works great with turbo street cars. IF you are running excesive amounts of boost id recomend the JG manifold
skunk2
Old Oct 13, 2003 | 10:34 AM
b18bEG's Avatar
on the street, I plan on running 10ish lbs, but on the track 15-20ish..
Old Oct 13, 2003 | 10:46 AM
InTeGrA B18b1's Avatar
Default Re: (b18bEG)
one guy with a ls put that on and he hated it and sold it.
Old Oct 13, 2003 | 10:51 AM
b18bEG's Avatar
did he have ls, or ls turbo
Old Oct 13, 2003 | 04:50 PM
DIRep972's Avatar
Smarter than you
I liked mine. I lost a some low end/spool up and lost a lil midrange but gained a lil top end too. it made the torque more flat to redline instead of falling off like the LS did.
Old Oct 13, 2003 | 06:00 PM
2K_TEG's Avatar
Default Re: ? on skunk2 I.M for ls turbo (DIRep972)
I don't have any hard proof, but word around the shops is that people like the Victor X better for turbo apps. Some GSR in turbo mag about a year ago gained twenty-some HP with the Victor X.
Kyle
Old Oct 13, 2003 | 06:06 PM
ahobbs's Avatar
HELLO,GOOD MORNIN'
Default Re: ? on skunk2 I.M for ls turbo (2K_TEG)
I was debating on getting one but Tony1 said at my boost level (11psi) would not help me. He said I would lose a little low end and gain maybe 5whp. I don't think it's worth it unless your running more than 15psi or so. At least to see some significant gains.
Old Oct 13, 2003 | 08:17 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bEG &raquo;</TD></TR><TR><TD CLASS="quote">did he have ls, or ls turbo</TD></TR></TABLE>
TuRBooooooo
Old Oct 14, 2003 | 04:28 AM
b18bEG's Avatar
hmm Im thinking then, maybe then just another stock I.M and TB, with a P&P? that would probably do the trick
Old Oct 14, 2003 | 06:15 AM
ahobbs's Avatar
HELLO,GOOD MORNIN'
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18bEG &raquo;</TD></TR><TR><TD CLASS="quote">hmm Im thinking then, maybe then just another stock I.M and TB, with a P&P? that would probably do the trick</TD></TR></TABLE>
Yeah it may help.
lsjon
Jan 23, 2007 11:46 AM
hybrid_vtec
20
Mar 1, 2005 02:00 PM
kyden
Feb 25, 2005 08:37 AM
gsrguy
Feb 3, 2004 01:36 AM
MIKES
Jun 4, 2002 07:32 PM
