D16Z6 Help
Old Oct 13, 2003 | 05:43 AM
redcivic's Avatar
Default D16Z6 Help
Just when I thought I knew everything about civics.....Well, as some of you know I sold my CRX and bought a white 92' VX hatch. I got an excellent deal on a brand new D16Z6 block ($390.00 ) and I plan on mating that with the head off of my original D16Z6 out of my 93' Coupe. Well I set the block on the stand next to the old block I have and I notice that if you are looking at the back of the block you have that long thick black cooling pipe that comes off the thermostat housing and runs to other end of the block to the water pump. Well on my old D16Z6 there is a little fitting where a hose that comes off the throttle body connects too. This fitting is located right before where that long black pipe connects on the water pump side. On the new D16Z6 I have that fitting is not there. Other than that, the blocks are identical. Can someone help please.
Old Oct 14, 2003 | 05:22 AM
redcivic's Avatar
Come one fellas.
Old Oct 14, 2003 | 05:31 AM
pro1342's Avatar
Swap the pipes?
Old Oct 14, 2003 | 08:16 AM
wickedEFguy's Avatar
Default Re: D16Z6 Help (redcivic)
are you talking about the coolant line coming from the thermostat going to the fast Idle Valve or the line going to the TB?
COLIMA0003ITR
Apr 19, 2014 07:55 PM
helldriver88
Nov 17, 2009 12:54 PM
4ghatch
Apr 24, 2008 09:00 AM
