What to do with the rear of the car??
Old Oct 13, 2003 | 02:04 AM
b18cx's Avatar
Default What to do with the rear of the car??
So I'm running 24.5'' tall slicks in the front with the car raised almost to stock height to clear (Groung Controll Coil overs). What should be done with the rear. Leave at street height(2 inch drop) or raise it a little to sorta level it out, or raise it to match the front?? This is of course for the track. Any info/experience appreciated.
Old Oct 13, 2003 | 03:51 AM
HYBRID_H@TCH's Avatar
Default Re: What to do with the rear of the car?? (b18cx)
I would like to know aswell...bump
Old Oct 13, 2003 | 04:41 AM
Jared's Avatar
For the rear get a good adjustable shock(kyb, tokico) set it on stiff, and get a set of skunk2 drag launch springs.
Old Oct 13, 2003 | 09:52 AM
b18cx's Avatar
Default Re: What to do with the rear of the car?? (Jared)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">For the rear get a good adjustable shock(kyb, tokico) set it on stiff, and get a set of skunk2 drag launch springs.</TD></TR></TABLE>
Ok, but that doesnot answer the question. What height would be perfered? droped 2 inches, raised up but not as much as the front, or match the front (stock height).
Have Koni yellow's with ground controll coilovers.
Old Oct 13, 2003 | 10:02 AM
PM-Performance's Avatar
i would match the rear and go from there, try diff things. diff things work for diff cars and set ups. i was told not to jack the rear higher like i was used to , becuase yoo much stress on the axles.
Old Oct 13, 2003 | 10:15 AM
lovitalracer's Avatar
Default Re: What to do with the rear of the car?? (itr206)
Is this a full race car or street car ??
Old Oct 13, 2003 | 02:34 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18cx &raquo;</TD></TR><TR><TD CLASS="quote">
Have Koni yellow's with ground controll coilovers.</TD></TR></TABLE>
If you got adjustable shocks and skunk2 drag springs for the back, there would be no adjustment for the rear.
Old Oct 13, 2003 | 07:35 PM
tony1's Avatar
You want the center of gravity as low as possible to minimize weight transfer...
Old Oct 13, 2003 | 08:02 PM
b18cx's Avatar
Default Re: What to do with the rear of the car?? (tony1)
thanks, again, tony. that right there answered the question
Old Oct 13, 2003 | 08:10 PM
T4eg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">You want the center of gravity as low as possible to minimize weight transfer...</TD></TR></TABLE>
cant say it any better
Old Oct 13, 2003 | 10:41 PM
OEMJDM's Avatar
Default Re: What to do with the rear of the car?? (BlueHatch00)
so in other words the lower the car the better? i need some help also
Old Oct 14, 2003 | 05:12 AM
tony1's Avatar
Default Re: What to do with the rear of the car?? (OEMJDM)
"You want the center of gravity as low as possible to minimize weight transfer..."
Tippyman
Jun 29, 2014 11:06 PM
AdamB18C1EK
Jan 16, 2009 10:55 PM
spoolinegsr
May 10, 2007 06:33 PM
Samuels
19
Jan 11, 2007 04:58 AM
whatVTEC
Jun 10, 2004 11:13 AM
