Ring gap location?
Old Oct 13, 2003 | 01:12 AM
DirtySoda's Avatar
Default Ring gap location?
Me and a friend were assembling a motor and when he put the pistons in and had the top 2 ring gaps 180 degrees apart and in line with the piston pin and the lower 2 ring gaps 180 degrees apart and perpendicular to the piston pin. After installing the head, he realized the error. The crank is not in yet, we can move the pistons up and down, but the head is bolted on and all valvetrain installed. Is this a huge problem? Can we spin the pistons around and get the gaps to move around a little? Any ideas?
Old Oct 13, 2003 | 05:01 AM
IN VTEC's Avatar
Default Re: Ring gap location? (DirtySoda)
If anything, the rings will stay in place and only the piston will move, but you'll never know if a ring gets snagged and moved along with the piston and how much.
Take the pistons out and move the rings. It's not that hard.
Old Oct 13, 2003 | 08:26 AM
jerseydevil's Avatar
Default Re: Ring gap location? (IN VTEC)
What is wrong with that setup? THe SRP pistons I just bought said to install them very similarly to that. THey had the top ring gap at 12 o'clock, the 2nd ring gap at 6 and the oil rings were located at @10/9/8 o'clock. The wrist pin here would be faceing from 9 to 3. I hope this isn't very wrong, my pistons are in already and the engien is all buttoned up.
Old Oct 13, 2003 | 03:28 PM
IN VTEC's Avatar
Default Re: Ring gap location? (jerseydevil)
Generally speaking, you don't want the top or second rings to be along the main thrust axes b/c they receive the bulk of the rotational forces thrusting the rings against the bores.
Old Oct 13, 2003 | 06:14 PM
So the ends of the rings will dig into the sleeve, or rings will crack? I'm gona take her apart and get it right. Just curious what will happen in that situation.
Old Oct 13, 2003 | 08:10 PM
IN VTEC's Avatar
I'm still unsure about all the theories and practices of cylinder ring clocking and positioning. People have said that they'll rotate anyways, so why bother, but if you don't fully understand the principles at work like I don't, then you should do things by the book. The Book says to keep them off the thrust axes and 180 degrees of separation b/w each ring gap.
ZCHondaCRX91
Engine Machining & Assembly
Feb 12, 2019 02:43 AM
siis2fast
Jun 7, 2005 03:52 AM
ssr_h22
Sep 6, 2004 09:21 AM
swlabhot
May 13, 2004 01:38 PM
B19CivicHB
Jun 19, 2003 04:15 PM
