AC with GSR radiator
i have a gsr swap. i took out the civic ac condensor with fan, to have a gsr radiator.
can i still use the ac without a condensor...how does the integra do this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirhatchalot5 »</TD></TR><TR><TD CLASS="quote">i have a gsr swap. i took out the civic ac condensor with fan, to have a gsr radiator.
??????????????</TD></TR></TABLE>
The tegs have the condensor mounted behind the rad but you can't do this with civics because tegs have a slightly longer front end allowing them to clear the exhaust manifold. If you want to keep AC, your best bet will be to use a OEM dual core (del sol VTEC) or better yet, a fluidyne.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah »</TD></TR><TR><TD CLASS="quote">
The tegs have the condensor mounted behind the rad but you can't do this with civics because tegs have a slightly longer front end allowing them to clear the exhaust manifold. If you want to keep AC, your best bet will be to use a OEM dual core (del sol VTEC) or better yet, a fluidyne.</TD></TR></TABLE>
no reason to shell out that kind of money for AC (Fluidyne). Go to your local AutoZone, Oreilly and get a Del Sol SI, Civic Coupe EX dual core rad, they're aluminum and only 100 dollars.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BLUE EH3 »</TD></TR><TR><TD CLASS="quote">wont a gsr rad with in a eg with no mods</TD></TR></TABLE>
Please tell me that English is not your first language
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec hatch05 »</TD></TR><TR><TD CLASS="quote">you don't need damn ac on a motor swap. it will just slow you down and it is 1 more belt for the pulley to turn over, you don't need ac and you don't need power steering. just my opinion</TD></TR></TABLE>
Of course he doesn't NEED the AC, but he wants it.
The integra has the condensor, it's just placed in front of the radiator. The lines are totally different. Do like they said above, buy a dual core radiator for your civic. I believe the LX models also have dual cores.
you make no sense. it dont slow you down. and it only slows if you have the AC turned on. the compressor has something like a flywheel. id like to keep the Ac though.. i went 2 summers w/o it. this is my 3rd gsr swap and 3rd civic too...not a newb
