Greddy Kit on LS w/out Intercooler dyno numbers??
Old Oct 12, 2003 | 08:20 PM
brianSilverTeg's Avatar
Default Greddy Kit on LS w/out Intercooler dyno numbers??
I'm looking to getting a Greddy kit for my 2k LS, but I'm a little tight on money. Since my car is bone stock at the moment, I have to throw in another 500 bucks or so for an exhaust, which kinda pushed me over my limit. Anyway, what kind of numbers could I expect if I decided to JUST run the Greddy kit without the intercooler?
Old Oct 12, 2003 | 08:26 PM
-iLLuZioN-B18C1's Avatar
Default Re: Greddy Kit on LS w/out Intercooler dyno numbers?? (brianSilverTeg)
depends how many pounds you plan on running?
if you are going to run less than 7 psi, i wouldnt expect much from it since the greddy turbos are smaller. your spool time will be nice, but max power is not going to be all that great unless your not expecting much.
Old Oct 12, 2003 | 08:33 PM
I plan on only boosting the stock setting the kit comes at for now. So yeah, not expecting huge gains. Just wondering if anyone knows of any concrete numbers running the kit without the intercooler. I believe the kit comes set at 5.5 or 6 psi, but I could be wrong on that.
Old Oct 12, 2003 | 08:34 PM
Default Re: (brianSilverTeg)
im taking a wild guess. 200 whp at 6-7 psi.
Old Oct 13, 2003 | 06:43 PM
Charlie Moua's Avatar
Default Re: (-iLLuZioN-B18C1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by -iLLuZioN-B18C1 &raquo;</TD></TR><TR><TD CLASS="quote">im taking a wild guess. 200 whp at 6-7 psi.</TD></TR></TABLE>
with just the blue box and injectors from the kit, it will be more like 180whp and 150tq 6.5psi stock setting
Old Oct 13, 2003 | 06:49 PM
What about using hondata to tune at the stock 6.5 psi without the intercooler kit but still using the injectors that come with the kit (330 I believe)?
Thanks for all the replies.
Old Oct 13, 2003 | 07:17 PM
bigwig's Avatar
310cc
Old Oct 13, 2003 | 08:29 PM
InTeGrA B18b1's Avatar
Default Re: (bigwig)
my ls with stock exhaust is Na until 4500 then it gets a little torquey.Im guessing around what charlie said 170-180 ish/ 145-155 sounds about right.
Old Oct 13, 2003 | 09:26 PM
Will a hondata s200 setup with boost option make any considerable power differences with this setup (I know it'll make it more reliable, which is why I plan on doing this)? And I do plan to get the intercooler kit, just wonderin if it's something I can put off for a bit.
singlecam screamer
Feb 4, 2005 05:12 AM
dubrand
Dec 3, 2004 06:09 PM
redteg
Dec 23, 2003 01:27 PM
