Tuning
Old Oct 12, 2003 | 05:50 PM
xci_ed6's Avatar
Default Tuning
So my plan was to tune to a specific A/F ratio across the board (but I'm used to turbo cars), but the guy I'm working with says we need to tune to the maximum torque, which can vary A/F in ratio depending on MAP/RPM.
Also, if I am right, what A/F ratio should I tune to?
This is an all-out race application.
-Dustin
Old Oct 12, 2003 | 05:51 PM
xci_ed6's Avatar
Default Re: Tuning (krustindumm)
Using an AEM w/ UEGO if that matters.
-Dustin
Old Oct 12, 2003 | 06:12 PM
Andrea's Avatar
You need to go with the air/fuel that will provide the most amount of power. In a N/A application your not trying to cool down the combustion chamber to the extent as with FI. Typically 13.5:1 air/fuel in WOT/atmospheric conditions is what makes the most power, but each engine is different and some will require richer/leaner. Set up the car on the street with 13.5:1 as a reference air/fuel, then see what the dyno tells you.
Old Oct 12, 2003 | 07:57 PM
xci_ed6's Avatar
Default Re: Tuning (50trim EK)
Cool, thanks.
So, just to make sure, are you saying that the a/f will be the same across the board, but what exactly it is will take work?
I also have an EGT on every cylinder, will that provide any usefull information for tuning other than a danger indicator?
-Dustin
Old Oct 13, 2003 | 06:37 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">but the guy I'm working with says we need to tune to the maximum torque, which can vary A/F in ratio depending on MAP/RPM.</TD></TR></TABLE>
He is correct - tune for maximum power with a safe A/F mixture (i.e. not extremely lean or rich). The mixture will almost definitely vary across the rev range.
Old Oct 13, 2003 | 06:42 AM
xci_ed6's Avatar
Default Re: Tuning (Padawan)
damn, that makes things complicaated.
-Dustin
Old Oct 13, 2003 | 07:41 AM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krustindumm &raquo;</TD></TR><TR><TD CLASS="quote">damn, that makes things complicaated.
-Dustin</TD></TR></TABLE>
That's why good tuners get paid the big bucks. Actually, I don't think it's that complicated. Just keep an eye on the A/F graph as you're concentrating on the power curve, and you shouldn't have too much trouble figuring out where and how to adjust it.
Rocket
Jun 16, 2005 09:21 PM
TWoody
Mar 17, 2005 11:14 AM
Benjithx
Jan 13, 2005 10:08 AM
cottagecreep
Oct 14, 2003 07:30 PM
97LudeSH
Sep 5, 2001 01:23 PM
