Which plugs do I run? 1'st gen B16a
Old Oct 12, 2003 | 01:16 PM
nmhybridog's Avatar
Default Which plugs do I run? 1'st gen B16a
Used to run NGK BKR6e-n11, but napa said they don't make them anymore. they have a bunch that have part numbers that are just like them but not that exact one. I know that one of the numbers in the part number is the heat rance. Anyone know which one it is? Is there denso plug I can run?
Old Oct 12, 2003 | 03:56 PM
chadmasterc's Avatar
Default Re: Which plugs do I run? 1'st gen B16a (nmhybridog)
try NGK part # 5724, i just got a box of ten from NAPA a few weeks ago.
Old Oct 12, 2003 | 05:43 PM
PURPLETERROR aka BIGMATT's Avatar
BKR6EN11, OR STOCK # 5724, AVAILABLE AT ANY ADVANCE AUTO OR DISCOUNT AUTO FOR $1.69 EACH ITS AN ORDER ITEM BUT YOU CAN USUALLY GET EM IN 1-3 DAYS
Old Oct 12, 2003 | 06:56 PM
Josh717's Avatar
all that plug is a heat range of 6 and a resistor plug, you could run a br6e plug and be fine.
Old Oct 12, 2003 | 08:12 PM
SeaBass's Avatar
From: Clueless like Shaggy n Scooby before commercial, break
Default Re: (Josh717)
BKR6E-N11for the plugs, wires are HE64
These were for NGK plugs bought from http://www.Sparkplugs.com
Old Oct 13, 2003 | 05:53 AM
jaydm98's Avatar
Default Re: (SeaBass)
are the spark plugs pre gapped already?
Modified by slopokb16crx at 3:10 PM 10/13/2003
Old Oct 13, 2003 | 10:25 AM
jaydm98's Avatar
Default Re: Which plugs do I run? 1'st gen B16a (chadmasterc)
Yeah BKR6E-N-11 or part#5724, got them for 2.19 a piece, and they were in stock,at napa auto.
Modified by slopokb16crx at 9:34 PM 10/13/2003
Old Oct 14, 2003 | 10:51 AM
jaydm98's Avatar
anybody know if the spark plugs pre gapped?
Old Oct 14, 2003 | 11:25 AM
manson's Avatar
Default Re: Which plugs do I run? 1'st gen B16a (slopokb16crx)
i always check the gap on any plug before i put it in....pre gapped or not.
Old Oct 14, 2003 | 11:29 AM
temp's Avatar
if you get them from honda they should be pre-gapped
Old Oct 14, 2003 | 04:35 PM
jaydm98's Avatar
Default Re: Which plugs do I run? 1'st gen B16a (temp)
Isnt the gap supposed to be set at .44?
Old Oct 14, 2003 | 04:36 PM
Snowboarding EF's Avatar
i need to change my plugs too
Old Oct 14, 2003 | 06:42 PM
bluecrxsi's Avatar
they need to be between .39 and .42 ideally and yes i always check mine also, even if they are preset!
SlowCivic29
Mar 10, 2007 03:33 PM
hotrex
Mar 30, 2005 03:16 PM
civicguy
Feb 11, 2005 05:42 PM
Chiller
Oct 29, 2004 08:18 AM
