does anyone think that sfp turbo kit is worth 3999.99 for a d series built.
Old Oct 12, 2003 | 12:09 PM
DRKSol's Avatar
Default does anyone think that sfp turbo kit is worth 3999.99 for a d series built.
sfp kits start a t 4000 and i was wondering that is it worth it or could i piece together the same for cheaper?
Old Oct 12, 2003 | 01:55 PM
SDT Project EF's Avatar
Default Re: does anyone think that sfp turbo kit is worth 3999.99 for a d series built. (jh)
that seems like a lot. I have no idea what the kit includes but i could imagine that you could build a kit on your own that is just as good for around 3k or maybe less depending on what you want. Talk to Project DC2 he helped me with putting together my kit along with many others.
Old Oct 15, 2003 | 09:41 PM
project dc2's Avatar
STAGE I (60% MORE HP OVER STOCK @ 7PSI) $3999.00
CUSTOM STAGE I PRECISION T3/T04E TURBOCHARGER
CUSTOM SFP TURBO MANIFOLD
SFP DOWNPIPE
STAGE I FRONT MOUNT INTERCOOLER WITH SFP POWDER COATED PIPES
TURBONETICS EXTERNAL WASTEGATE
HKS BLOW-OFF VALVE
FMU
255 LPH IN TANK FUEL PUMP
STAGE I UPGRADED INJECTORS
APEX-i V-AFC WITH CUSTOM TUNED STAGE I FUEL MAP FROM SFP
ALL NECESSARY HARDWARE REQUIRED FOR INSTALLATION
*AVAILABLE FOR D15, D16, B16, AND B18 MODELS*
yeah .. you can DEFINATLEY piece togehter a cheaper kit
Old Oct 15, 2003 | 09:56 PM
ExospeedAMcrx's Avatar
Default Re: does anyone think that sfp turbo kit is worth 3999.99 for a d series built. (project dc2)
sounds similar to a DRAG or REV HARD kit (+ a couple other things)
Old Oct 15, 2003 | 10:04 PM
T4eg's Avatar
Default Re: does anyone think that sfp turbo kit is worth 3999.99 for a d series built. (exospeedAMcrx)
like stated above. you could piece together a better kit for less
Old Oct 16, 2003 | 12:26 AM
whoDAT's Avatar
Default Re: does anyone think that sfp turbo kit is worth 3999.99 for a d series built. (BlueHatch00)
$3999.99?!?! ARE YOU OUT OF YOUR MIND?
Old Oct 16, 2003 | 04:40 AM
ladysman's Avatar
Default Re: does anyone think that sfp turbo kit is worth 3999.99 for a d series built. (whoDAT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoDAT &raquo;</TD></TR><TR><TD CLASS="quote">$3999.99?!?! ARE YOU OUT OF YOUR MIND? </TD></TR></TABLE>
Exactly, I pieced together a custom kit that will kill it including hondata and injectors for a hell of a lot less than that.
Old Oct 16, 2003 | 04:48 AM
JDMCRX's Avatar
Default Re: does anyone think that sfp turbo kit is worth 3999.99 for a d series built. (ladysman)
Man piece one together man alot cheaper and plus that whole VAFC hack is ghey
rod64
Oct 30, 2006 03:36 AM
9200RPM
Sep 7, 2004 03:15 PM
evilgsr
May 3, 2004 08:50 AM
boosted hybrid
Apr 8, 2004 06:56 AM
EL'ation
Jul 3, 2003 11:16 PM
