Which LS Block is the best to do Ls/vtec?
Old Oct 12, 2003 | 11:41 AM
DumpedSi's Avatar
Default Which LS Block is the best to do Ls/vtec?
I have found a couple 90-93 for pretty cheap but im just curious would it be best performance wise to go with a 94+ or even an OBD2 block, this motor will be going in a 2000 si with a si tranny head...
Old Oct 12, 2003 | 11:43 AM
Pho Real's Avatar
Default Re: Which LS Block is the best to do Ls/vtec? (Slammed Si)
I think the 94-01 block would be btter than the 90-93.... I think the newer the better actually
Old Oct 12, 2003 | 11:45 AM
DumpedSi's Avatar
cool. any other opinions?
Old Oct 12, 2003 | 11:47 AM
EARLdaSQUIRREL's Avatar
official honda whore
there the exact same block.. only differences between the 90-93 and the 94 up is the obd and the head differences
Old Oct 12, 2003 | 11:54 AM
Pho Real's Avatar
Default Re: (coptzer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coptzer &raquo;</TD></TR><TR><TD CLASS="quote">there the exact same block.. only differences between the 90-93 and the 94 up is the obd and the head differences</TD></TR></TABLE>
If they are the same block what is the difference with the B18A as opposed to the B18B?
Isnt the 90-93 the B18A? and the 94+ blocks are b18b right?
Old Oct 12, 2003 | 12:56 PM
Sketch_hs's Avatar
Default Re: (Pho Real)
why not b20?
Old Oct 12, 2003 | 01:18 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pho Real &raquo;</TD></TR><TR><TD CLASS="quote">
Isnt the 90-93 the B18A? and the 94+ blocks are b18b right?</TD></TR></TABLE>
the only differences are in the head
90-91 are even different from the 92-93, the differences are in the head
94-00 are same everything at 92-93 basically except hydro trans.... blocks are same throughout.... but if you can get a newer block by all means get a newer one unless you plan on changing internals anyways....
Old Oct 12, 2003 | 01:19 PM
shermanyang's Avatar
Default Re: (Sketch_hs)
the difference between the LS's motor are as:
90-91 B18A motor...ODB0 130 hp (poor head design/combustion/ports)
92-93 B18A motor...ODB1 140 hp (better head design)
94-95 B18B motor...ODB1 140 hp (same thing)
96-01 B18B motor...ODB2 143 hp (don't know how they got that extra 3 hp)
Old Oct 12, 2003 | 05:11 PM
dew1996si's Avatar
go b20 ... you'll be much much happier
Old Oct 12, 2003 | 07:06 PM
DumpedSi's Avatar
Default Re: (dew1996si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dew1996si &raquo;</TD></TR><TR><TD CLASS="quote">go b20 ... you'll be much much happier</TD></TR></TABLE>
I dont really want to go crv-tec because I've heard the sleeves always crack and Im only gonna be using this as a semi-daily driver and I dont want to have to put any money into it that I dont have to
Old Oct 12, 2003 | 07:55 PM
ThisLittleSleepeR's Avatar
Default Re: (shermanyang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang &raquo;</TD></TR><TR><TD CLASS="quote">the difference between the LS's motor are as:
96-01 B18B motor...ODB2 143 hp (don't know how they got that extra 3 hp)</TD></TR></TABLE>
can you tell me which ones came with cable or hydro tranny?
Old Oct 12, 2003 | 08:13 PM
Garrett's Avatar
90-93 have cable tranny
94-01 have hydro tranny
Old Oct 12, 2003 | 09:24 PM
Spartanic's Avatar
Default Re: (Slammed Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed Si &raquo;</TD></TR><TR><TD CLASS="quote">
I dont really want to go crv-tec because I've heard the sleeves always crack and Im only gonna be using this as a semi-daily driver and I dont want to have to put any money into it that I dont have to</TD></TR></TABLE>
So whats the reason that the sleeves always crack? I don't see how this can happen unless your always beating on it. Is it because the sleeves are so thin becuase its bored to 84mm?
Old Oct 14, 2003 | 05:30 PM
JdmegFOUR's Avatar
Default Re: (Spartanic)
b20 with stock sleeves but damn i wish i would have sleeved it they cracked all
$ down the drain=( i think im going w a vetc block
Old Oct 14, 2003 | 05:33 PM
Dr. EKology's Avatar
I think you guys are all wrong about the block. I believe the B18A's have knock-sensors and the B18B's do not, or vice-versa. But the blocks are not identical.
Old Oct 14, 2003 | 05:36 PM
JdmegFOUR's Avatar
Default Re: Which LS Block is the best to do Ls/vtec? (EVIL_EKology)
correrct some.......
Old Oct 14, 2003 | 07:20 PM
Default Re: Which LS Block is the best to do Ls/vtec? (JdmegFOUR)
Time for an EKology 'Learnage' session
B18A blocks do not have knock sensors (won't matter if you use p28) and they also have the PCV system on the block (like all other B-Series VTEC motors), while B20 & B18B have them on valvecover.
Old Oct 14, 2003 | 09:25 PM
JdmegFOUR's Avatar
94 has on back of block ?no
1jdmek
Jun 12, 2023 03:20 PM
kdshroyer
17
Nov 18, 2011 03:55 PM
tray3rd
10
Jun 9, 2004 02:25 AM
syndicate43
Aug 26, 2003 05:01 AM
