tein SS settings and camber?
Old Oct 12, 2003 | 11:08 AM
MikeyDB7's Avatar
Default tein SS settings and camber?
I did a search but did not come up with my answer
What are your settings on your Integra Tein SS coilovers...
during daily driving?
and during sprited driving?
also.. Im lowering my Integra about 1 inch and a half... from your experience..when will I need a camber correction kit?
thanks for the help guys..
oh yea..and just to be sure.. turning the teins all the way to the right will set it at 16.. then just count down from there to get the right setting that you want... is this how the tein SS work?
Old Oct 12, 2003 | 11:23 AM
six_speed's Avatar
Default Re: tein SS settings and camber? (MikeyDB7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MikeyDB7 &raquo;</TD></TR><TR><TD CLASS="quote">I did a search but did not come up with my answer
oh yea..and just to be sure.. turning the teins all the way to the right will set it at 16.. then just count down from there to get the right setting that you want... is this how the tein SS work?</TD></TR></TABLE>
first off......
All the way right (clockwise)...hardest (1)....you start out on hte haardest.
then start to turn (counter clockwise) for softest (16).
you start out on hardest and turn counter clockwise to softer settings.
i run 5f/5r..it's not too rough. i do really notice and feel if the roads arenot constantly flat. the seting i chose is for both occasions...normal and spirited.
Hondas' in general will have camper/toe once lowered.
1=~ -.75 degree
2=~ -1.5 degree
3=~ -2.50 degree
Just be on the look out for your tires...like check them once a week to see if the inner tires are being worn....etc.
Old Oct 12, 2003 | 11:42 PM
MikeyDB7's Avatar
Default Re: tein SS settings and camber? (Humping_dragon)
hey thanks for the info
Old Oct 13, 2003 | 12:09 AM
lustedp's Avatar
there is a recommended setting in the booklet. I'd use that for daily driving. If you make the rear too stiff, it has a tendency to make it come out too easily and really unstable in my opinion. That's been my impression with this and the other tein dampers
Old Oct 13, 2003 | 01:12 AM
MikeyDB7's Avatar
Default Re: (lustedp)
thanks for the caution..
preludepower01
Suspension & Brakes
Mar 9, 2008 01:35 PM
hondc5
Feb 22, 2007 10:25 PM
dc2955556
Suspension & Brakes
12
Jul 3, 2006 03:09 AM
PrittyPearllude
Suspension & Brakes
Apr 11, 2006 06:50 PM
tgrace
Jan 15, 2004 03:42 PM
