CRX HX / GS-R swap need help
O.k bought an crx hx i want to put in an 94 gsr motor but some guy said it won't work because the hx does not have an fuel return line is this true if so what can i do to change it. can some tell me who makes the kit for the cable to hydro convert.
also has anyone had a weight problem with a b series motor like flipping over.
I'm assuming you meant a crx HF, in which case you wont need to convert to mpfi, it already is. As for the fuel line I've never heard of such a thing. As for the weight it will make no difference in rolling over, in fact being as low as it is it may even help keep you from rolling over.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio 95 »</TD></TR><TR><TD CLASS="quote">thanks, what do you guys think it will run in 1/4 because i all ready gutted it. plus i have a vtec controler set at 4200. </TD></TR></TABLE>
Dont set your vtec that low...its a stock gsr im assuming...leave it where it belongs go to hasport.com they have all info...and u should try searching before u go postin like this...its been covored 100 times.
ill hit it up with my trademark
