Properly storing a bike for the winter
Old Oct 12, 2003 | 10:04 AM
Thasty's Avatar
Default Properly storing a bike for the winter
F3 needs to be stored this month. All i gotta do is fill up the tank and put in stabalizer, anything else?
Old Oct 12, 2003 | 11:40 AM
SLATER97EX's Avatar
Default Re: Properly storing a bike for the winter (OnlyNod)
park it on carpet squares or put it up on stands....some people use a battery tender too...
Old Oct 12, 2003 | 03:18 PM
big pete's Avatar
Default Re: Properly storing a bike for the winter (SLATER97EX)
I would change the oil. Try to start it once a week
Old Oct 12, 2003 | 06:38 PM
ScubaStevo80's Avatar
Default Re: Properly storing a bike for the winter (big pete)
Run a normal maintenance on it. Clean it thorougly, change the oil and filter if it needs it, lube and clean the chain, spray all linkages down, and try to drain the tank as much as possible and put stabilizer in it. Fuel sediments settling in the bike is no good. Keep it on a charger and start it once in awhile. Also, remember to move the bike up and back a foot at a time frequently. This way you dont' get flat spots on the tires. If i missed anything, let me know.
Old Oct 13, 2003 | 07:05 AM
Thasty's Avatar
Default Re: Properly storing a bike for the winter (VolpeOwnsU)
shouldnt you fill up the tank and then put the stabalizer in it?
Old Oct 13, 2003 | 09:25 AM
big pete's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnlyNod &raquo;</TD></TR><TR><TD CLASS="quote">shouldnt you fill up the tank and then put the stabalizer in it? </TD></TR></TABLE>
yup
Old Oct 13, 2003 | 11:33 AM
You put a certain amount of stabilizer in per the amount of gas you have in the tank... I keep about half a gallon in my bike and put that much stabilizer in it. I know many people who leave alot of gas in their bikes over the winter and when they go to start it, they have probs, and end up finding out they have injector/fuel pump/fuel line deposits from the gas settling and the sediments being sucked in.
Old Oct 13, 2003 | 10:40 PM
Nikki_rider's Avatar
Livng in snowy Utah, I have found that any day with dry roads gives me a chance to take a short ride. I try to do this once a week if possible, if not start the bike weekly. This will keep the bike working. Also, some times it is fun to bunddle up and take a ride around the city. Dry roads is the key.
Old Oct 14, 2003 | 12:19 PM
bigpun418's Avatar
Clean the bike, get an oil change (not necessary), take out the battery, and add fuel stabilizer. If you don't take the battery out, you'll have to start it once every 2-3 weeks and you'll be good.
Old Oct 14, 2003 | 12:48 PM
baddassduramax's Avatar
Default Re: Properly storing a bike for the winter (bigpun418)
make sure your fuel tank is full, then put stabilizer in or you will get condensation in your tank if its not full!
Old Oct 14, 2003 | 02:23 PM
Thasty's Avatar
Default Re: Properly storing a bike for the winter (civicb18)
All the guys sayin you need to turn it on every now and then are wrong. Unless you can get the bike up to full operating temperature you are doing more harm than good. This I know, the rest of the suggestions i will take in, Thanks.
Old Oct 14, 2003 | 02:28 PM
georgiajdm's Avatar
does jersey snow for months or just a couple days. in ga. you can ride around through the neighborhoods cause the roads are snowed up maybe a couple days out of winter. granted it's cold as **** but it can be done.
Old Oct 14, 2003 | 02:44 PM
Thasty's Avatar
Default Re: Properly storing a bike for the winter (georgiajdm)
Oh yea you can ride here. Its definatly cold, it dipped into the negatives for over a month last winter. We got hit hard with snow last year also, I think it only snowed about 5 times, but they were hard. One was like 28inches of snow. Compelete BS, i hate cold weather and snow. Goin out to AZ in a month to check out colleges, should be nice.
Old Oct 16, 2003 | 11:57 AM
Apocalypse's Avatar
n00b question: Are the steps taken to store a bike for the winter a function of the lower frequency with which you ride or the colder temperature, or both?
Old Oct 16, 2003 | 12:07 PM
D16OnTop's Avatar
disconect the battery for sure
tonydatyga
Honda Motorcycles
50
Nov 4, 2007 07:15 PM
quicksilvia
Honda Motorcycles
16
Jun 3, 2006 12:10 AM
9deuce9rr
Honda Motorcycles
10
Oct 17, 2005 06:47 PM
BeeT
Honda Motorcycles
Sep 14, 2003 01:08 PM
nerdish
Honda Motorcycles
Dec 28, 2002 01:56 PM
