DA knuckle for B16A HF?
Old Oct 12, 2003 | 07:24 AM
inline4's Avatar
Default DA knuckle for B16A HF?
Putting a jdm b16a into crx hf, can you use the knuckle and hub off of a DA (90-93 Integra)? If so, which axles, including inner half shaft, do you use?
Regardless, which axles?
Did search, coudln't find anything on using DA knuckles.....
Thanks in advance.
Old Oct 12, 2003 | 07:35 AM
Rob!'s Avatar
Default Re: DA knuckle for B16A HF? (inline4)
yes you can use DA knuckles. it all depends on which intermediate shaft you have for axles though....90% of the time ur going to need 90-91 inegra axles because u will have the shorter of the 2 intermediate shafts....the other 10% is when u have the longer intermediate shaft and your going to need 90-91 intagra passenger shaft and 86-89 itegra drivers side shaft...i had the longer shaft and i had 2 brand new 90-91 axles so instead of getting a 86-89 teg drivers side axle i changed my int. shaft to the shorter one because if u use the 86-89 one the inner cv is too short and easier to brake....but most likely u hav the shorter one and 90-91 will do the trick any questions pm me or somethin....also hasport.com gave me most of my info when i was a n00b to ths.
Old Oct 12, 2003 | 07:42 AM
inline4's Avatar
Default Re: DA knuckle for B16A HF? (b16hf)
Ok, the found out that the driver's side axle is too long. It's from a DA, so should I get a driver side axle from a 86-89 integra? Or a shorter halfshaft?
Old Oct 12, 2003 | 07:50 AM
Rob!'s Avatar
if you dont have a lot of power and just have like a stock internal nonturbo b16 then just go with the 86-89 axle...if u have or plan to go seious theni would get shorter int. shaft....and just so u know if te drivers side is too long when u make a left turn your car will shake like crazy. thats what mine did.
Old Oct 12, 2003 | 07:55 AM
inline4's Avatar
ok, so what year is the short int. half shaft? I'm not sure which one I have now, but I know that I have the 90-93 integra driver side axle and it's too long, so I will need the shorter one, so what year does that come from?
Old Oct 12, 2003 | 07:59 AM
Rob!'s Avatar
there is a jdm int. shaft and a 90-93 integra intermediate shaft. the 90-93 teg one is longer...just buy a 86-89 drivers side axle and you will be fine.
Old Oct 12, 2003 | 08:00 AM
inline4's Avatar
ok, thanks for all your help
nexgen91
Mar 26, 2006 08:44 AM
tmihok
Aug 7, 2004 03:34 PM
XANDER-666
Oct 7, 2002 12:04 PM
dustin
10
Apr 3, 2002 12:53 PM
juicy.koreans.suck
10
Jan 10, 2002 10:47 AM
