DA knuckle for B16A HF?
Old Oct 12, 2003 | 07:23 AM
inline4's Avatar
Default DA knuckle for B16A HF?
Putting a jdm b16a into crx hf, can you use the knuckle and hub off of a DA (90-93 Integra)? If so, which axles, including inner half shaft, do you use?
Regardless, which axles?
Did search, coudln't find anything on using DA knuckles.....
Thanks in advance.
EDIT: I know wrong forum sory....
Old Oct 12, 2003 | 10:22 AM
philly-O's Avatar
Default Re: DA knuckle for B16A HF? (inline4)
you can use dx or si knuckles from a 4th gen also. the hf has a different spline.
Old Oct 12, 2003 | 03:00 PM
jaydmcrx's Avatar
I got them on my car and they work great. I have the whole upper control arm and rotor calipers and hub assembly. Got them for free too
Old Oct 12, 2003 | 07:52 PM
iwhichisme's Avatar
yea the da knuckles will work out for you hf. the teg axles are what youll need as far as they do. Depending on what tranny you use will determine exactly what axles you go with. the y1, s1, j1 trannies all use the 90-91 teg axles, and the ys1 tranny uses the 92-93 (i beleive this is correct, but double-check).
Old Oct 12, 2003 | 08:13 PM
Caleb V's Avatar
Default Re: DA knuckle for B16A HF? (iwhichisme)
Your alignment isn't going to be in good shape and the Teg knuckles are taller than a Civic/CRX as well. 90-91 Civic EX knuckles are sweet if you want big brakes but you still have to pop the dust ring off of them to get the DA axles to work with them.
Old Oct 12, 2003 | 11:13 PM
CRX-RX's Avatar
Default Re: DA knuckle for B16A HF? (Caleb V)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Caleb V &raquo;</TD></TR><TR><TD CLASS="quote">Your alignment isn't going to be in good shape and the Teg knuckles are taller than a Civic/CRX as well.</TD></TR></TABLE>
So in short, can you; yes. Should you; no. to any DA suspension peice on an EF chassis.
Old Oct 13, 2003 | 03:01 AM
Caleb V's Avatar
Default Re: DA knuckle for B16A HF? (CRX-RX)
Ditto that, most people want to know why it shouldn't work.
firejackal
Jul 12, 2012 10:11 AM
SkunkCrxSi
11
Jul 19, 2004 11:54 AM
inline4
Oct 12, 2003 08:00 AM
50shotRex
Feb 16, 2003 05:07 PM
CBR
Apr 14, 2002 07:15 PM
