Reset Switch for the 7th Gen Accord
Old Oct 12, 2003 | 01:17 AM
gsumaylo's Avatar
Default Reset Switch for the 7th Gen Accord
Does the new 2003 Honda Accords have a reset switch to turn off the "Maintenance Required" light in the dash panel? I know most old model Acura Integras have them underneath the panel below the steering column but I can't seem to find it. It would sure help, since the light is programmed to stay on after every 10,000 miles. This means that I'd have to service it at the dealership just so they could reset the light. I sure don't want to pay an arm and a leg for a simple oil change and fluid check at the dealers, when I could reset it myself, after every 10,000 miles. Please give me some info on this matter if anyone knows. THanks a lot everyone.
Old Oct 12, 2003 | 06:16 AM
pogidawgie's Avatar
Default Re: Reset Switch for the 7th Gen Accord (gsumaylo)
The "maintenance required" light omes on every 6500 miles and to reset it press and hold the reset button on the dash while turning the ignition on (do not start the engine). Keep holding the reset button and the light should go away after 10 seconds.
Old Mar 14, 2004 | 04:17 PM
z4hokie's Avatar
Default Re: Reset Switch for the 7th Gen Accord (pogidawgie)
This doesn't seem to work for me. Any other suggestions?
vinceg143
Mar 9, 2009 10:59 AM
pacpark4
May 15, 2005 09:59 AM
sinister357
Sep 21, 2004 12:20 PM
sharkey65a
Mar 18, 2003 07:06 AM
redteg1
Jan 13, 2002 08:52 AM
