92-95 radiator just put in...car over heats some need help!pics pls!
Car is heating up some.....I have the fan on a switch and its running all the time but welp sometimes the car will go to half on the temp gauge trying to clime but I turn on the heater full blast and it drops down....but most of the time its fine....i have a turbo kit on my d16a6 greddy kit so.....how is yours mounted in? does it over heat how many fans is on it? pictures pls?
did you bleed your system? how old is your thermostat? i'd recommend changing the thermostat if it's old. drain your system again and bleed it. put 50/50 in it, start the car with the cap off, and let it get hot. just keep it running and make sure your heater vent is open so it gets the air out of the heater core. once it looks like there are no more bubbles coming out of the radiator, put the cap on and drive it. park, let it cool and check again. i run just one fan on the inside drawing heat away from the radiator. the fan should only need to be on at low speeds when there is not enough air cooling the radiator. besides, it is a hp draw
Got a new thermostat and I bled the coolant system ....the thermostat was in the car when it over heated once and we replaced the headgasket so Im thinking maybe it messed it up?
Was the rad new when you got it?
Check the rad for cold spots. When the car is getting on the hot side, pop the hood and feel the rad fins, if some are colder then others then the rad is plugged.
Ill check for cool spots...it wasnt new but it was in perfect working order before I got it.... I'm gonna try a new thermostat tommorow since old one might be dmg'd and go with some of that coolant temp dropping ****.
sounds like time for a mugen low temp thermostat, might as well if your gonna replace it w/ a stock one
fuglybutruns
Jul 28, 2015 07:50 PM
SlowB16
Feb 22, 2013 05:59 PM
408maro
25
Oct 19, 2010 06:42 PM
spock_rocker
Jun 6, 2005 03:32 PM
