How do I adjust my KYB AGX shocks?
Old Aug 30, 2001 | 12:33 PM
95civic's Avatar
New User
Default How do I adjust my KYB AGX shocks?
I received my shocks in the mail today and was looking at them but am unsure how to adjust them. How many different settings should there be? Is it 4 in the front and 4 in the back? I drive a 95 civic ex coupe. Thanks for any help.
Old Aug 30, 2001 | 01:00 PM
thinkbrianthink's Avatar
Default Re: How do I adjust my KYB AGX shocks? (95civic)
there is a 'screw' at the top of the shock tower. you use a small flathead screwdriver and turn that screw. there should be numbers around the screw. i think the higher the number, the stiffer the shock.
brian
Old Aug 30, 2001 | 06:30 PM
RedRacer's Avatar
New User
What Brian said. Your shocks should have came with a couple of small yellow handled flathead screw drivers. Just insert the screw driver into the top of the shock rod, (make sure you press down before you turn!!) and turn to the number you want. Shocks increase stiffness as the number increases.
FirstAdition1
Dec 2, 2003 06:46 PM
brwnrice
Oct 29, 2001 11:44 AM
d0nkeyxPunch
Jul 25, 2001 05:41 PM
