what times should i see out of my eg
i have a 92 si eg with a 97 ls motor so far the motor is stock im running a t60-1 stage 5 ballbearing turbo with fmic the fuel system is h22 injectors with a walbro in tank pump with 2 extra 440cc injectors on the charge pipe. im running a 35 shot of nos to help spool the turbo which has a .82 ar on the exhaust side and a full dc cat back exhaust . the car will run on 24 inch slicks with traction bars at about 12 psi of boost the ignition is set up with a msd digital sci plus and msd wires and coil with a msd btm... what times should i expect out of this set up...thanks
im going to say 14.0. so when you clock in faster then that, you wont be dissappointed. no honestly, your setup seems wicked, too many varibles.
all in all it sounds pretty quick. go run it and keep us updated.
Its all depend on how tune your car are? If everything is tuned and no signs of any probs then I'll say high 12 to low 13s!!
If not properly tune, mid 13 to mid 14.
Yeahh... you need to take it to the track and tell us how you did!!
