HOw do you Check the CEL on a odb0 with odb1 conversion??
Old Oct 11, 2003 | 06:35 PM
xmd's Avatar
xmd
Default HOw do you Check the CEL on a odb0 with odb1 conversion??
How do you do it? what pinns do you jump?!
-x m d
Old Oct 11, 2003 | 07:18 PM
lelopez's Avatar
Default Re: HOw do you Check the CEL on a odb0 with odb1 conversion?? (xmd)
Jump the same pins you jump when you check your timing. The plug is either on the engine bay or on the right side of the footrest on the passenger side of the car (u have to lift the carpet).
Jump that plug and count the times the check engine light flashes........this is the code #.
good luck,
L.
Old Oct 11, 2003 | 08:11 PM
y49crxsi's Avatar
Default Re: HOw do you Check the CEL on a odb0 with odb1 conversion?? (lelopez)
Did you use a harness to do it, or did you make it yourself.
Anyways, when you do get it flashing, long flashes are 10, and short little flashes are 1.
Old Oct 12, 2003 | 12:19 AM
acongdon's Avatar
Short D4 to D21
speed_demon018
Mar 12, 2010 06:47 AM
rz514
Honda Civic (2006 - 2015)
Jul 30, 2006 05:48 PM
99IntegraGS
May 3, 2004 07:18 AM
D16A6Turbo
30
Apr 23, 2004 12:21 PM
Jimmy
Oct 7, 2003 11:34 AM
