HELP ME OUT PLZ
Old Oct 11, 2003 | 05:33 PM
89dohcEF's Avatar
Default HELP ME OUT PLZ
i just drifted into a curb and my tire is now 1 inch from the side of the fender. the fender isnt fucked up my alignment is. how can i fix it. so when i break my tire rubs on the bottom of the wheel well because its so close to the door/fender . what can i do
Old Oct 11, 2003 | 07:30 PM
blah13's Avatar
Default Re: HELP ME OUT PLZ (zc_civic91)
Sounds like you either busted your radius rod or your LCA (lower control arm) and possibly your upper one too is bent to hell. Check the nut on the end of the radius rod (front of the crossmember) and see if its still there, and check the 2 rubber "bushings". Then compare the control arms to the ones on the other side of the car. Hopefully you just stripped the threads or busted those bushings.
Old Oct 11, 2003 | 08:20 PM
hybrid93SIvic's Avatar
Default Re: HELP ME OUT PLZ (blah13)
my advice to you when you get it fixed...don't drift
corpsebesideme
11
Aug 21, 2016 01:11 AM
followthadollar
Apr 27, 2010 08:32 PM
OBDII Integra
Jul 19, 2009 09:41 AM
Untamed_Hatred
Feb 18, 2008 06:41 PM
black7hatch
13
Nov 4, 2006 07:09 PM
