Koni Threaded Suspension vs. Eibach Pro-Kit + Koni shocks??
Old Aug 30, 2001 | 12:12 PM
Philbert's Avatar
Default Koni Threaded Suspension vs. Eibach Pro-Kit + Koni shocks??
I am interested in reducing the wheel well gap on my integra and improving the handling, but don't want to make the ride unbearable. How do the springs that are part of the new Koni threaded suspension kit differ from the Eibach pro-kit? What are the pros/cons of each setup?
Thanks for your help,
Phil
Old Aug 30, 2001 | 09:04 PM
Abez's Avatar
Default Re: Koni Threaded Suspension vs. Eibach Pro-Kit + Koni shocks?? (Philbert)
Do you want to have the option to adjust your height or do you want to lower your car and not mess with it anymore? If you want the adjustability, then I sugest you go with a Ground Control Coilover + Koni shock combo. They are easier to adjust compared to the Koni Threaded Suspension and at the same time cost less. The stiffness of the ride will depend on your spring rates and the condition your shock are in. I have the GC coilovers + Koni yellows combo and the ride is pretty sweet.
Old Aug 30, 2001 | 09:46 PM
strils's Avatar
if you can fork out the cash get the Apex coilovers(the true coilover). the handling with those are unreal compared to coilover sleeve/shock combos. A friend of mine has ProKit and Koni Yellows and its smoothe and you can adjust ride height with the Yellow's perch setting anyway.
Jintegragsr97
Suspension & Brakes
Oct 3, 2009 01:11 PM
travisallenn
Suspension & Brakes
Nov 30, 2006 04:55 PM
B18CYAAA
Jun 30, 2003 09:27 PM
doe
Jul 29, 2002 09:44 PM
