steering column question
if you want a tilt wheel, why not just use a CRX Si column? then it's sure to fit.
But just so you know, there's more to it then just hte column.
It sounds like a winner....I will post the results after I do my car this morning
its one of my 'pet' projects for the day. I took the steering assembly from
the parts car and will place it into my HF rex.
laterz
laterz
The si steering column will work...the only problem is that the key cylinder
assemblyis attached with 'shear bolts'....i did not see a way to work around
that so I tossed the column, oh well.
laterz
laterz
I put a tilt column from a 88 CRX DX in my 91 Std hatch.Goes right in,no problems.I had to use the CRX ignition switch cause my Civic one wouldn't fit the CRX column,but the CRX switch would fit the Civic coulumn.Ah yeah,and a mighty useful tip...you remove the pinch bolt from INSIDE the car...lol.
inegma29
Feb 7, 2008 12:15 PM
alscrx
Jan 25, 2008 06:51 PM
Grnade
Jul 16, 2005 08:02 AM
Gant
16
Feb 25, 2005 09:38 PM
djay86
16
Aug 13, 2002 03:32 PM
