taillights: taking out the amber part so they are red and white
Old Oct 11, 2003 | 11:38 AM
tha Big EZ's Avatar
Default DIY: taillights: taking out the amber part so they are red and white
I took the amber out of my taillights and replaced it with "crushed glass" plastic sheeting. It looks a whole lot better! thought I'd let you guys know it was real easy. Thanks.
Modified by tha Big EZ at 2:07 PM 10/14/2003
Old Oct 11, 2003 | 11:48 AM
crxforum's Avatar
Default Re: taillights: taking out the amber part so they are red and white (tha Big EZ)
Do you have pics?
CRX Forum
Old Oct 12, 2003 | 07:58 AM
tha Big EZ's Avatar
Default Re: taillights: taking out the amber part so they are red and white (crxforum)
Ill try and post some later, do i have to be subscribed to a host site to upload them to this site? I have never put pictures up! let me know how and ill put them up. And it looks sooooooooooooooooooooo much better than having the amber in!
Old Oct 12, 2003 | 08:30 AM
crxforum's Avatar
Sign up with imagestation and you will be ok. http://www.imagestation.com sign up and copy the URL of the image inbetween the [IMG][/IMG] tags.
CRX Forum
Old Oct 12, 2003 | 09:35 AM
JMD's Avatar
JMD
Got a write up about how you did it?
Old Oct 12, 2003 | 09:56 AM
iam7head's Avatar
Default Re: taillights: taking out the amber part so they are red and white (siqcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siqcivic &raquo;</TD></TR><TR><TD CLASS="quote">Got a write up about how you did it?</TD></TR></TABLE>
we dont even know what kinda of tail light it is.
Old Oct 14, 2003 | 01:07 PM
tha Big EZ's Avatar
Default Re: taillights: taking out the amber part so they are red and white (iam7head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iam7head &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, thats my bad! I took the amber part out of my 96 Prelude taillights. To do this,
1. I took the lights off the back of the car. And took off the foam piece on the back of the lights. (so as to not toast it in the oven)
2. took a cookie sheet, and put a flat layer of tin foil ( so the light isnt sitting directly on anything hot enough to melt it, the physical light that is!) on the sheet, then set the taillight on the tin foil in my oven, on Bake, @ 250 degres F for 3-4 minutes.
3. I then pulled the light out of the oven and wedge a butter knife in between the red plastic and black housing at the top point of the light, just enough to fit a flat in the space to seperate the two. They will come apart farely easy because the oven melts the glue thats holds them together. Open the taillights from top to bottom!!!!!!
4. Pop out amber and clear piece out of the red plastic side!
5. Relplace with plastic sheeting, you bought form Home Depot or Lowe's, that is used to put in ceiling lights in schools or in kitchens. It comes in about a 2 1/2 foot by 2/1/2 foot square. I used the "crushed glass" sheeting instead of the raised squares! I think it makes for a more interesting look. but its your choice. I also used a glue gun with black glue sticks to hold the sheeting in place. Super glue, glue gun, or plastic epxoy will work too!
6. semi squeeze both housings back together, and sit in oven to re-melt the glue(2-3 minutes). Once glue is re-melted, squeeze botn sides together till it is back how it started, sealed shut!
7. replace lights.
8. turn on hazards to notice your new weapon against tail-gaters. Mine seem to be SUPER bright, so if someone is tailing my *** real bad, I hit them on and they back up real quick!
9. enjoy
Ill get pics up asap! thanx for checkin this out
Old Oct 14, 2003 | 02:55 PM
purplehazek4's Avatar
i think prelude is the only tail light you can do that to.
Old Oct 14, 2003 | 03:02 PM
streetlights's Avatar
Default Re: taillights: taking out the amber part so they are red and white (purplehazek4)
i wanna see!
deadline
Apr 25, 2007 07:58 AM
supertrogdor
May 24, 2004 09:28 AM
Worangejuice
Nov 23, 2003 10:53 PM
tha Big EZ
Oct 21, 2003 10:45 AM
CRXtc 90
14
May 16, 2002 08:55 PM
