d16z6 to jdm d15b
Well last night i was ****** around on the freeway and spun a rod bearing, so im looking for a replacement. HMO sells the d15b long blocks for $435, seems like it would be a decent swap to upgrade with since im broke as ****.
Question:
Any wiring changes or does it all plug right in?
Trannies bolt up??
Opinions and options please tell me.
Question:
Trannies bolt up??
im kinda looking for the same thing all the D series trannys match up, but if its ganna be vtec head or what not... yeah different wiring harness.. other wise all "plug n play"
if you need the engine right away, get the d15b. if you can do without it for a while, a b16a2 or a b18b sounds very nice.
either way, you're upgrading so it doesn't really matter. Good luck with it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by al3e »</TD></TR><TR><TD CLASS="quote">oh i guess i was wrong... ive been told some wont be plug n play if you dont have the harness but oh well </TD></TR></TABLE>
if youre going from a d16z to a d15b, then its plug and play literally.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dampachi »</TD></TR><TR><TD CLASS="quote">if you need the engine right away, get the d15b. if you can do without it for a while, a b16a2 or a b18b sounds very nice.
either way, you're upgrading so it doesn't really matter. Good luck with it.</TD></TR></TABLE>
yeah i need it ASAP, i plan on doing a swap in february too which sucks. I found a cheap long block locally, so if that falls through d15b here i come.
either way, you're upgrading so it doesn't really matter. Good luck with it.</TD></TR></TABLE>yeah i need it ASAP, i plan on doing a swap in february too which sucks. I found a cheap long block locally, so if that falls through d15b here i come.
