Battery light going crazy!!!!
Old Oct 11, 2003 | 09:36 AM
Starbucks_91b16acrx's Avatar
Default Battery light going crazy!!!!
i just recently changed my battery about a week or two ago.. all of a sudden about last saturday.. my battery light started to flicker on and off, seems like everytime i hit a bump or take a turn the battery light turns on.. i checked my battery connection and its on there pretty good... some say it might be my alternator... i need some secondopinions before i get anything repalced..
thanks guys
Old Oct 11, 2003 | 09:44 AM
MrTodd's Avatar
Default Re: Battery light going crazy!!!! (91b16aCRX)
A similar thing happened to me a while back... My battery light would spontaneously flicker on and off sometimes during normal driving. It did NOT do it only when turning, or hitting bumps like you explained. It turned out that the brushes on my alternator were going bad, so I replaced the alternator with a life-time warranty autozone remanufactured unit.
It really sounds like your issue has to do with your wiring harness. Perhaps the negative or positive battery terminal is loose, if not that then some of the grounds might be corroded or loose. If everything checks out okay with the wiring harness, then I'd go ahead and replace the alternator.
Old Oct 11, 2003 | 01:19 PM
blah13's Avatar
Default Re: Battery light going crazy!!!! (MrTodd)
Since you checked the battery connections check the alternator ones as well.
Old Oct 11, 2003 | 01:34 PM
Default Re: Battery light going crazy!!!! (blah13)
thanks guys
Old Oct 11, 2003 | 01:36 PM
Hondasaurs's Avatar
Pull the negative off of your battery. If the car dies your alt is bad.
Old Oct 15, 2003 | 10:52 PM
Default Re: Battery light going crazy!!!! (Hondasaurs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hondasaurs &raquo;</TD></TR><TR><TD CLASS="quote">Pull the negative off of your battery. If the car dies your alt is bad.</TD></TR></TABLE>
yea i figuered my car took ashit on me
Old Oct 15, 2003 | 11:07 PM
carsaregood's Avatar
this happened to me as well.. well more so my light would fade in and out, randomly. turned out to be my alternator... which was pretty new. so that sucked...
Old Oct 15, 2003 | 11:27 PM
Default Re: Battery light going crazy!!!! (carsaregood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carsaregood &raquo;</TD></TR><TR><TD CLASS="quote">this happened to me as well.. well more so my light would fade in and out, randomly. turned out to be my alternator... which was pretty new. so that sucked... </TD></TR></TABLE>
the lights on my climate control, cluster, and headlights where diming, then my tach was going crazy, then my car died...
it sucked but its fixed now
CRX baby
Jun 2, 2019 02:39 PM
meelow
Apr 29, 2010 09:35 PM
MDAnhorn
Dec 28, 2007 04:15 AM
Vtecme92
Oct 10, 2005 07:18 PM
