FS/FT: Halmeter Air/Fuel meter
Old Oct 11, 2003 | 07:48 AM
Simple's Avatar
Default FS/FT: Halmeter Air/Fuel meter
This is the most acurate meter for Air/Fuel there is
Essential to High Performance
An essential part of tuning any high performance engine is knowing whether the air fuel ratio is correct. A rich mixture will lead to a loss of power, while a lean mixture may result in detonation. The Halmeter AF30 provides a thirty LED readout of air fuel ratio, right there, in the cockpit, while you drive.
Exhaust Gas Analysis with the Halmeter
and the Lambda Oxygen Sensor
The design of the lambda or oxygen sensor provides a signal which is easily interpreted by the Halmeter AF30. The sensor produces a small voltage outout by comparing free oxygen in the exhaust gases with ambient oxygen outside the exhaust system. This voltage is created when the sensor is heated to between 360 degrees centigrade (680 F) and 900 degrees centigrade (1650 F) and varies between zero and one volt. The AF30 processes this voltage output and displays the result via a series of red, yellow and green LEDs: the red lights for lean, yellow for the stoichiometric band and green lights indicating mixtures likely to produce maximum power. It should be noted that, in the event the sensor is located in the exhaust where the temperatures are at or above the maximum, a reduced voltage output will result in fewer lights in the green band being lit at rich mixtures.
Dividing the small output from the sensor into thirty incremental LED's gives the Halmeter AF30 superior resolution compared to other instruments of its type.
The Halmeter AF30 Air/Fuel Ratio Indicator offers the tuner a low cost, attractive unit with thirty LED indicators that signal lean-optimum-rich.
The HalmeterAF30 Air/Fuel Ratio Indicator works on all engines, carbureted or injected, and with gasoline, alcohol or propane fuels. When used with programmable EFI systems, it helps establish fuel maps and makes the mixture trim control a more precise tool for on track tuning.
The Halmeter AF30 Air/Fuel Ratio Indicator kit is supplied complete with meter, wiring harness, oxygen sensor and exhaust fittings.
The Halmeter AF30/2 kit contains two oxygen sensors, with a special wiring loom and switch, to enable the user to monitor both sides of a dual exhaust system.
Dimensions
Height 1.875" 47.6 mm
Width 3.5" 76.2 mm
Depth 0.875 22.2 mm
Modified by Simple at 10:34 PM 12/15/2003
Modified by Simple at 8:30 AM 3/18/2004
Old Oct 11, 2003 | 05:44 PM
Simple's Avatar
Default Re: FS/FT: Halmeter Air/Fuel meter (Simple)
ttt
Old Oct 15, 2003 | 07:15 AM
FatJoe's Avatar
bump for a friend
Old Oct 15, 2003 | 07:18 AM
Flexmyrex's Avatar
Default Re: FS/FT: Halmeter Air/Fuel meter (H22Accord90DX)
so it comes w the harness and the o2 sensor?
how much
Old Oct 15, 2003 | 07:31 AM
Simple's Avatar
no o2, i had it wired to the ECU
Old Oct 15, 2003 | 07:38 AM
OneFastGsr's Avatar
pm sent
Old Dec 15, 2003 | 09:33 PM
Simple's Avatar
Default Re: FS/FT: Halmeter Air/Fuel meter (OneFastGsr)
still up for grabs....
Old Dec 16, 2003 | 09:24 AM
Simple's Avatar
ttt
Old Dec 16, 2003 | 09:32 AM
pierrot le fou's Avatar
pm sent
Old Dec 16, 2003 | 09:39 AM
Simple's Avatar
Default Re: FS/FT: Halmeter Air/Fuel meter (ronmcdon)
replied to!
Old Dec 16, 2003 | 11:48 AM
1BadDC2's Avatar
bump for good seller
Old Dec 19, 2003 | 11:08 AM
Default Re: FS/FT: Halmeter Air/Fuel meter (1BadDC2)
is this pt sold already?
Old Dec 23, 2003 | 06:20 PM
Simple's Avatar
nope, still up for grabs
Old Dec 23, 2003 | 07:18 PM
Bbasso's Avatar
Price, just curious...
Old Dec 23, 2003 | 07:42 PM
Simple's Avatar
Default Re: FS/FT: Halmeter Air/Fuel meter (Bbasso)
will sell for 50
Modified by Simple at 8:31 AM 3/18/2004
Old Dec 23, 2003 | 08:01 PM
quik2kSi's Avatar
wiring the same as autometer A/F gauge? or is it a bit more complex givin that it come new sensors? autometer's are ****.
Old Dec 24, 2003 | 12:08 AM
Simple's Avatar
Default Re: FS/FT: Halmeter Air/Fuel meter (quik2kSi)
i think this one actually wires into one of your o2 wires comming off the sensor. i know that it read really good when i took it out. hella more acurate than my autometer one
Old Mar 18, 2004 | 07:30 AM
Simple's Avatar
to the top, will sell for 50
Old Mar 18, 2004 | 04:56 PM
Simple's Avatar
$50 and no one wants the most acurate A/F guage on the market? How about trades for D series shift linkage, or D series Axles?
Old Mar 18, 2004 | 05:17 PM
t0eKnEe's Avatar
sent pm
Old Mar 19, 2004 | 06:22 AM
Simple's Avatar
Default Re: FS/FT: Halmeter Air/Fuel meter (t0eKnEe)
PM'd you back
Old Mar 19, 2004 | 09:43 AM
Simple's Avatar
sold
PurpleAccord88
Mar 18, 2008 09:35 PM
TWoody
Mar 17, 2005 11:14 AM
Ex-ITR5874
Sep 24, 2001 08:05 AM
austrian type-R
Sep 17, 2001 12:41 PM
