Crower street/race valve springs ok for toda spec b's?
Old Oct 11, 2003 | 12:58 AM
blwnb16a's Avatar
Default Crower street/race valve springs ok for toda spec b's?
I have some crower steet/race valve springs (part number 68185) and i wanted to know if I could use them with some toda b specs i just bought
Old Oct 11, 2003 | 10:10 AM
asubennett's Avatar
Default Re: Crower street/race valve springs ok for toda spec b's? (blwnb16a)
theoretically yes, but always check the compressed height of the spring and then subtract the max lift of the cam which is 12.00mm for the toda b from the figure you got from the compressed spring this will give you the amount fo clearence you have. I like to see .035 but it seems like wth the 12.5 mm lift cams the springs always yiel between .020 to .025. This very close but has been ok for the most part.
Old Oct 11, 2003 | 10:07 PM
blwnb16a's Avatar
Default Re: Crower street/race valve springs ok for toda spec b's? (asubennett)
bump
Old Oct 11, 2003 | 10:19 PM
ALLMTRWHORE's Avatar
your fine. If you seem to be worried about it then get a different valvetrain for peace of mind, but I have never heard of anything bad of them. what do you plan to rev to? what's your setup? I mean this can dictate if it can be safe to be run in your motor with your intention to rev high.
Old Oct 11, 2003 | 11:25 PM
TimoneX's Avatar
New User
Default Re: Crower street/race valve springs ok for toda spec b's? (ALLMTRWHORE)
They'll be fine. That's the recommended spring for Crower 63403s that I run. That cam is very similar with a 12.04mm lift.
Old Oct 15, 2003 | 06:33 PM
blwnb16a's Avatar
Default Re: Crower street/race valve springs ok for toda spec b's? (TimoneX)
ttt
Old Oct 27, 2003 | 12:50 PM
blwnb16a's Avatar
oops
baysic r
Jun 29, 2009 11:49 PM
SuperImport
Apr 22, 2006 11:12 PM
Integra-DC5
Aug 19, 2002 06:59 PM
powerfulperformance
May 5, 2002 05:16 PM
