Yo, got a CRX and a 1.6vtec from a del sol Si- will it fit direct or do I need mounts?
Old Oct 10, 2003 | 10:22 PM
range
Guest
Posts: n/a
Default Yo, got a CRX and a 1.6vtec from a del sol Si- will it fit direct or do I need mounts?
any help would be great thanks-
Old Oct 10, 2003 | 10:50 PM
Malgerus's Avatar
Default Re: Yo, got a CRX and a 1.6vtec from a del sol Si- will it fit direct or do I need mounts? (range)
what year del sol si?
Anyways, yes, you'll need to use all the mounts and brackets for the mounts off of your existing 88-91 engine/transmission. However, you do need to grind down the driver's side timing belt engine mount, or the belt will rub.
xChrizcrozzx
Aug 21, 2014 05:15 AM
ryanjoseph
Mar 7, 2008 05:43 PM
busted240
Feb 3, 2008 09:38 PM
roosta 1
May 18, 2005 09:18 PM
