5th gear syncro bad
Old Oct 10, 2003 | 08:56 PM
xkhalil333x's Avatar
Default 5th gear syncro bad
do i need to fix this problem immediately? if i dont fix it will there be any long term problems.
Old Oct 10, 2003 | 08:59 PM
bartek_b's Avatar
Default Re: 5th gear syncro bad (xkhalil333x)
if your 5th gear syncro is bad, I'd think that this should be fixed asap
Old Oct 11, 2003 | 08:49 AM
Dr Pooface's Avatar
Default Re: 5th gear syncro bad (mugen85r)
Unless your shifting in andout of 5th on a constant basis and the grinding is buggin you, I see no reason to droop the trannyto only fix that. Wait until you have to replace the clutch. Then throw in a light flywheel and an ATS FD to make it worth your while.
Old Oct 11, 2003 | 10:29 AM
Default Re: 5th gear syncro bad (Dr Pooface)
that what i wa sthinking, when i shift 5th im gonna always shift below 3
SoCalian_SD
Jan 18, 2009 07:43 AM
94jdmlude
Dec 30, 2008 02:38 PM
tegG2
Honda Motorcycles
Aug 21, 2005 01:08 PM
AgentUT
Apr 18, 2004 06:39 PM
missinghubcabs
Jun 25, 2003 03:41 PM
