Sk2 Stg2 cams w/ CTR pistons in LS block? Clearance Issues?
Old Oct 10, 2003 | 08:33 PM
3rdGteg's Avatar
Default Sk2 Stg2 cams w/ CTR pistons in LS block? Clearance Issues?
Anyone ever used this setup? Ls block with the pct slugs and running the Skunk2 Stage 2 cams in a b16a head? Was there any clearance issues?
Old Oct 10, 2003 | 10:42 PM
EF_LSVtec's Avatar
Default Re: Sk2 Stg2 cams w/ CTR pistons in LS block? Clearance Issues? (3rdGteg)
you'll be fine. Friend of mine has CTR pistons on his LSVtec w/ spec C Toda's, (higher lift than stage 2) and he has no clearance issues...
Old Oct 10, 2003 | 11:09 PM
216.226.142.95:27016's Avatar
Default Re: Sk2 Stg2 cams w/ CTR pistons in LS block? Clearance Issues? (EF_LSVtec)
but we all know the real way to find out is to clay the motor
Old Oct 11, 2003 | 02:32 PM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: Sk2 Stg2 cams w/ CTR pistons in LS block? Clearance Issues? (216.226.142.95:27016)
I wonder how many times a day I saw clay the motor?
Old Oct 11, 2003 | 04:19 PM
jdmcx's Avatar
what about Sk2 Stg2 cams w/ CTR pistons in LS block and gsr head
Old Oct 11, 2003 | 09:24 PM
Supernatural's Avatar
check my sig ......with similar set up....clearance isnt goint to be and issue unless you milled the head (alot)
Old Oct 11, 2003 | 09:50 PM
Combustion Contraption's Avatar
what about clay the motor
Old Oct 13, 2003 | 08:04 PM
3rdGteg's Avatar
Default Re: (LsVtec92Hatch)
Thanks for the replies...
oneslodx
25
Apr 4, 2008 04:44 AM
sloweredcivic
Oct 2, 2004 11:25 PM
arw321
Jan 20, 2004 10:37 AM
JUNcr-x
Nov 21, 2003 06:19 AM
