I need your help... so stressed out.
Old Oct 10, 2003 | 08:17 PM
Grease Monkey's Avatar
Default I need your help... so stressed out.
I was in the process of doing my mpfi swap. I ran into so many problems like hoses and stuff. My major problem today was the dizzy. The DX dizzy connector is different to the SI dizzy. One is 5 wire and the other is 7. I understand I need to extend both the blue wires on the SI dizzy to the ECU. My question is, how did you all compensate for the connector? This is my major problem. I already setup all the vaccum lines and coolant lines. I also finished installing the intake manifold. What I dont understand is, how come almost all the write ups are the same(from sport compact) and not one write up i read speaks of the dizzy. Can anyone tell me whats going on? TIA!
**EDIT**
I also forgot to add that I also have 2 green plugs and a brown plug left. Theres some sort of sensor on the rightt side of the intake mani and the connector looks like a different shape. Does anyone know what that is and how do I connect it?
Old Oct 10, 2003 | 08:53 PM
Default Re: I need your help... so stressed out. (Grease Monkey)
Can anyone help me? Its round number two tomorrow and I dont want to give up.....
Old Oct 10, 2003 | 09:00 PM
Outsane's Avatar
try this site.
http://www.geocities.com/c_rexboy/mpfi.html
The DX dist won't work with the MPFI set up.. you need a SI dist...
You maybe able to use an HF dist..but I can't confirm that..
I can say that the DX and the SI dist are different internally..
Old Oct 10, 2003 | 09:12 PM
Default Re: I need your help... so stressed out. (Outsane)
Still doesnt answer my question about the dizzy connector. ANyone else got any ideas?
Old Oct 10, 2003 | 09:17 PM
phatrick2332's Avatar
you have to either depin, and repin ur old dx connector, or add the si connector on to ur harness.
Old Oct 10, 2003 | 09:18 PM
JDMHatch101's Avatar
i changed all of my wires around by unplugging them and reinstalling them where needed.
Old Oct 11, 2003 | 06:01 AM
Default Re: (JDMHatch101)
But the problem is, I see two white wires on both dizzys. I'm guessing maybe it was a different color and faded over time?
Old Oct 11, 2003 | 12:33 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
Default Re: (Grease Monkey)
http://www.angelfire.com/d20/h....html
Old Oct 11, 2003 | 01:54 PM
Default Re: (88DXCRX)
I now have the car running but for some odd reason when I give it gas it revs back and fourth quickly. It idles fine. Anyone have any ideas?
Old Oct 11, 2003 | 02:08 PM
EG8R's Avatar
I used the DX connector on the Si dizzy. Popped out pins snad put them in the right places. Used a 2 pin connector for the other 2 wires....
Old Oct 11, 2003 | 02:13 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey &raquo;</TD></TR><TR><TD CLASS="quote">I now have the car running but for some odd reason when I give it gas it revs back and fourth quickly. It idles fine. Anyone have any ideas?</TD></TR></TABLE>
Still having problems and I have a check engine light. There is no L.E.D on my ecu. 1990 CRX(MT) PM6. Anyone know how to check the code?
I need to get my car out of a freinds house ASAP!!
Old Oct 11, 2003 | 05:23 PM
OK. I finally got it running and it runs great but I still have a CEL! Also, what am I supposed to do with the Fast idle valve? There is no connector for me to connect it and the clips dont even match. ANy ideas?
Old Oct 11, 2003 | 06:21 PM
EG8R's Avatar
Don't use it....
Old Oct 11, 2003 | 08:29 PM
civickiller's Avatar
Default Re: (skelly ed6)
what code you geting ? look at the ecu and tell us how much times it blinks
Old Oct 12, 2003 | 07:01 AM
Default Re: (civickiller)
thats the problem!! There is no L.E.D on the ecu and I dont know if I should solder a new one. Is there anyother way to check the codes like jumping any clips?
Would the fast idle be causing the code?
I dont really know if I'm running rich but the exhaust gases definitly does not smell the same. Has a strong smell to it now. Car runs good but sometimes the throttle cable makes the throttle body stuck at like 1500 or 2000 rpm.
Any ideas?
Old Oct 12, 2003 | 08:59 AM
up
Old Oct 12, 2003 | 10:19 AM
91civicEX's Avatar
you need to put an led in your ecu or get a new ecu. theres no way around it.
Old Oct 12, 2003 | 01:43 PM
Default Re: (91civicLX)
Re checked all my wiring. The weird this is, there are 2 white wires on the dizzy. if you flip it around one way, the car wont start but the check engine light goes away. If I flip it the other way, the will start but there will be a check engine light. All wires are hooked up correctly and so is the ecu side. I have no idea what to look for. As far as the ecu, hopefully I can get a L.E.D soldered on there to figure the code out but I cant do it untill Tuesday. Anyone else have any ideas on what to check? Does it matter that both of the yellow and black wires are not on the resistor box? I have only the thicker gauge on there and the smaller gauge is just hanging. Do I need to add that wire? Is it possible it may be causing the CEL? Again, the car runs and drives excellant. Just the annoying CEL.
Old Oct 12, 2003 | 02:09 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey &raquo;</TD></TR><TR><TD CLASS="quote">up</TD></TR></TABLE>
Old Oct 12, 2003 | 04:28 PM
bump....
Old Oct 12, 2003 | 07:04 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Grease Monkey &raquo;</TD></TR><TR><TD CLASS="quote">bump....</TD></TR></TABLE>
Old Oct 12, 2003 | 10:02 PM
u mean the light went out or theres no light there ?
Old Oct 12, 2003 | 10:21 PM
Caleb V's Avatar
I always solder the 2 YW/Black wires together and then with one pin add them to the injector box. No fast idle on the LS so you don't use it. Did you move C1, C2 to B10 B12 and add CYL sensor wire to C1 C2? Bl/YW Bl/GR? Did you switch the outer TPS wires around? Get an led on there for now. Fast idle if you have it is a cylinder shaped solenoid with a square 2 pin connector on the drivers side back of the intake manifold. Bl and Bl/YW
Old Oct 13, 2003 | 06:17 AM
Default Re: (Caleb V)
I did all the wire swaps. However, I did not use both yw/black wires. The sport compact mag said to use the bigger gauge YW/Black wire. Would that even cause a CEL? The ECU did not have a L.E.D and I cant check the code untill tomorrow after my job interview. I guess I'm going to have to solder the L.E.D but I will definitly try and wire up the smaller gauge YW/Black wire to the big gauge. Anyone else have any ideas?
Old Oct 13, 2003 | 06:38 AM
I dont really know if I'm running rich but the exhaust gases definitly does not smell the same. Has a strong smell to it now and I dont know what the deal is on that.
