itr front lip install
Old Oct 10, 2003 | 04:24 PM
sdchump's Avatar
Default itr front lip install
i was just glancing at my OEM lip and the ends, there are 4 screw holes that are horizontal in direction. i was wondering if those mount into some holes on the front of my car, cuz i dont recall any holes pointing that way.
do i have to drill holes into my fender to mount the lip, or is there some bracket that i need. all i have are the clips that have nuts welded to them, that slip into the factory plastic at the bottom of the car. any help is appreciated. thanks.
Old Oct 10, 2003 | 07:33 PM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: itr front lip install (sdchump)
I think I know what you are talking about. At the end of the lip there are two holes on each end. If you look in your fender well you'll see a black screw holding the wheel well liner. Once you take it off you will see that there is also a notch above that for another screw. You'll need to drill that hole out. Once you install the lip both holes on each end will line up with the holes on the fender well area. You'll need to buy two more of those screws and a couple retainers to hold the screws in place, just like the ones that are on that one screw holding the fender well liner.
I didn't have one so I used the retainer from the bumper lights and just got a screw and bolt to hold the bumper lights in place.
Hopefully I was clear in my explanation. let me know if you have any other questions or if you need clarification. If you test fiot the bumper in place you will see what I'm talking about.
Good luck!
civicsareslow
13
Jul 1, 2008 10:13 AM
Samuels
May 11, 2008 11:28 AM
sdchump
Oct 10, 2003 04:23 PM
2000GSR
Mar 19, 2003 07:23 AM
integranator
Dec 9, 2002 06:47 AM
