Anyone's Autometer A/F Gauge break?
Old Aug 30, 2001 | 07:19 AM
HX_Guy's Avatar
Default Anyone's Autometer A/F Gauge break?
As of two days ago...my AF Gauge only cycles from off-the-scale lean to the first stoich LED. Crusing or WOT...same thing.
When I stop and the car idles...ALL the LEDs light up!
What the hell is the deal with that?
Is it the gauge? Is my car actually running that lean?
Old Aug 30, 2001 | 07:21 AM
non-VTEC's Avatar
Default Re: Anyone's Autometer A/F Gauge break? (HX_Guy)
add as much fuel as you can and see if it changes.........if it does not check the connection to the A/F guage. if there ok then the guage might be fucked.
Old Aug 30, 2001 | 07:24 AM
Evil DOHC's Avatar
Default Re: Anyone's Autometer A/F Gauge break? (non-VTEC)
Connect a volt meter to the o2 sensor and do a wot pull, it should say .90 or higher at full throttle. If its lower, then you are running lean. Also try checking your plugs to see what color they are.
Hope this helps.
EVIL
Old Aug 30, 2001 | 07:31 AM
HX_Guy's Avatar
Default Re: Anyone's Autometer A/F Gauge break? (Evil GS-R)
Yea I checked the plugs and they all checked out ok.
Im going to hook up a mutlimeter to the O2 sensor and see what it says.
I was also thinking maybe the O2 sensor was bad...but I tried switching the A/F Gauge to the 2nd O2 sensor..and same results...and I doubt both O2 sensors would go bad at the exact same time.
peddyeye
Dec 1, 2008 01:52 AM
teler86
Jun 30, 2005 03:55 AM
LudeyKrus
May 17, 2003 05:34 AM
hatchy
Aug 23, 2002 10:41 PM
