Contemplating buying a 91 standard. Pros and cons of buying it.
Old Oct 10, 2003 | 02:44 PM
wannab20hatch's Avatar
Default Contemplating buying a 91 standard. Pros and cons of buying it.
Im considering buying a 91 civic standard. I know their the lightest hatches and that with a swap you have to at least change to dx brakes but other than that what are some pros and cons of buying a standard vs. buying a dx. thanks for all the help
Old Oct 10, 2003 | 04:48 PM
JDMHatch101's Avatar
first thing the standard and dx are basically the same thing. pros easy swaps, lightest hatches, parts are very cheap. cons hard to get wired right if you do it yourself the right way, changing all of the parts for a swap.
Old Oct 10, 2003 | 09:01 PM
d357r0y's Avatar
Default Re: Contemplating buying a 91 standard. Pros and cons of buying it. (wannab20hatch)
Consider buying mine.
Old Oct 10, 2003 | 09:37 PM
JackAcc's Avatar
Default Re: Contemplating buying a 91 standard. Pros and cons of buying it. (d357r0y)
I have the STD.... LOVE IT!!
Just had a Y8 dropped in with a 5 speed.... so sweet...
Yes wiring is a pain.. plus needed new axles and hubs...but maybe it is just because I saw such a HUGE difference in performance after the swap that I am such an advocate...But if you can pick it up cheap enough...parts are everywhere especially if you drop in a d series motor.. (z6, y8, etc..) nice power gains for little $$... Good luck!
Old Oct 12, 2003 | 05:01 PM
Default Re: Contemplating buying a 91 standard. Pros and cons of buying it. (JackAcc)
thanks guys for all the help. Ive had a 91 dx before and really liked it. I just got back home from buying the standard and im in love all over again. I got it for 650 bones and drove it home. Already got a 91 si cluster for it and dx front brakes(until i can afford bigger or better)
Old Oct 12, 2003 | 05:53 PM
Caleb V's Avatar
If you are going with a D-motor and don't have the money for DX/SI/EX knuckles then you can mount the calipers on your knuckles and reuse the axles since the outer spline count is different from the DX/SI knuckles and they have the same tranny cups. Let me know if you need a wiring conversion.
Aaron Jones
Apr 25, 2020 08:45 AM
killaflex
Apr 17, 2006 01:12 PM
VtecSyndrome
16
Jan 29, 2006 09:55 PM
bootsz420
Oct 9, 2005 11:56 PM
indianajones
Aug 11, 2005 10:56 AM
